R through a wire: What's the max error in diameter if your R has 1% uncertainty?
4 replies · 2K views
anban
I have a wire of some resistance, resistivity, and length.
What is the maximum error in measuring the diameter that you can have if the resistance is to have 1% uncertainty?
R = [itex]\frac{ρ*l}{\pi*r^{2}}[/itex] for which I substituted the area as [itex]\pi[/itex](.5 D) ^{2}.
I picked an arbitrary R and found the corresponding D. Then, I took 1% of that arbitrary R and found the corresponding D. The issue is that D's were basically the same number. I'm not sure if I could just go out to more decimal places or if I'm just wrong...
R = [itex]\frac{Rρl}{\pi*r^{2}}[/itex] .
You meant R = [itex]\frac{ρl}{\pi*r^{2}}[/itex] , didn't you?
Solve the problem symbolically. If the resistance can differ from R by one percent it can be 1.01 R or 0.99 R. What are the corresponding diameters and how are they related to the original D? By what percent are they different from it? ehild
Typo, thank you!
Big help! Turns out I was off by a decimal point. My answer makes a lot more sense now. Thank you very, very much.
Another clarification-- the D in the denominator is squared. Does that mean I need to take the square root of my result?
