Radial solutions to laplace equation
The discussion centers on the conditions under which solutions to the Laplace or Poisson equations can be assumed to be radial in nature, particularly in the context of polar coordinates. Participants explore the implications of boundary conditions and the dependence of functions on angular variables.
  • Some participants propose that solutions can be considered radial when boundary conditions are constant in theta and the function f depends only on r.
  • Others question the conditions under which the term involving the second derivative with respect to theta can be ignored, suggesting that it vanishes when u is a function of r only.
  • A participant suggests that if u is linear in theta, the second derivative term would drop out, but they express uncertainty about how to determine when a solution is linear in theta.
  • Another participant mentions that the Laplacian's rotational invariance implies that solutions may lack theta dependence, seeking clarification on this point.
  • One participant raises a concern about the physical implications of a linear dependence on theta, noting potential discontinuities at theta=0 and theta=2π.
  • A later reply emphasizes that if f has no theta dependence, the resulting differential equation will only involve r, allowing for radial solutions.
  • It is noted that if boundary conditions and the domain shape are rotationally invariant, the solution will also be rotationally invariant, but this is contingent on the uniqueness of the solution based on specified conditions.
Participants express various viewpoints on the conditions for radial solutions, with no consensus reached on the specifics of when theta dependence can be disregarded or the implications of linearity in theta.
Limitations include the dependence on specific boundary conditions and the assumptions regarding the nature of the function f, as well as the implications of rotational invariance on the solutions.
wumple
Hi,
When can I assume that the solution the laplace equation (or poisson equation) is radial? That is, when can I look only at (in polar coordinates)
[tex]\frac{\partial u^2} {\partial^2 r} + \frac{1}{r} \frac{\partial u} {\partial r} = f(r,\theta)[/tex]
instead of
[tex]\frac{\partial u^2} {\partial^2 r} + \frac{1}{r} \frac{\partial u} {\partial r} + \frac{1}{r^2}\frac{\partial u^2} {\partial^2 \theta} = f(r,\theta)[/tex]
With appropriate boundary conditions of course. My guess is any time that the boundary conditions are constant in theta and f depends only on r? But I'm not really sure.
Thanks for any help!
-wumple
wumple said:
Hi,
instead of
[tex]\frac{\partial u^2} {\partial^2 r} + \frac{1}{r} \frac{\partial u} {\partial r} + \frac{\partial u^2} {\partial^2 \theta} = f(r,\theta)[/tex]
-wumple
Look at [tex]\frac{\partial^2u} {\partial\theta^2}[/tex] When would this term vanish from the equation...
when [tex]u = u(r)[/tex] only?
Yes if u(r) only then it would surely drop out. But that is not the only way... For a moment ignore the partial and just think of it like a normal derivative, more specifically notice it is a second derivative. When would the second derivative of some function equal zero?
when it's linear in theta? How do you know when the solution is linear in theta?
Yes, when its linear in theta. How do you know when its linear in theta...thats a good question. I will have to do a little thinking on that one, this stuff is kinda new to me as well ;). Hopefully that gives you at least some idea and if I come up with something I will keep you updated.
I think it has to do with the laplacian being rotationally invariant - hence no theta dependence. See sec 8.3/8.4:
http://www.math.ucsb.edu/~grigoryan/124B/lecs/lec8.pdf
could anyone else explain this a bit better? Is that true - if a PDE is rotationally invariant, its solutions will have no theta dependence (or some of them do anyway)?
After doing some thinking I don't know if 'u' can be linear in theta (at least physically). Because if it was linear in theta then at theta=0 'u' would have some value, while at theta=2pi 'u' would have some different value despite the fact that theta=0 and theta=2pi correspond to the same physical point. Thus if it was linear in 'u' there would be a discontinuity. That being said the only thing that would satisfy it is u=u(r)
wumple, the intuition is really all that you need- if we assume that f has no dependence on theta, we get a differential equation only involving r, so we can find solutions involving only r. Compare that with this proposed differential equation:
[tex]\theta \frac{\partial f}{\partial r} + f = 0[/tex]
If you assume that f doesn't depend on theta, then you still have a theta in your differential equation and things get confusing.
In terms of when your solution is going to be rotationally invariant - if your boundary condition is rotationally invariant and the shape of your domain is rotationally invariant then your solution will be rotationally invariant as well - otherwise, rotating the whole problem yields the same exact problem but a different solution (this is assuming that things are specified to the point where there is a unique solution)
  • · Replies 36 ·
  • · Replies 16 ·
