Radian and Degree with Graphing Calculator
The TI-83 Plus graphing calculator can easily convert angles between radians and degrees by adjusting the mode settings. Users can switch between radian and degree modes by pressing the mode button located next to the 2nd button. To convert a degree measure to radians, input the angle, select the degree symbol, and the calculator will output the radian equivalent. Alternatively, for a manual conversion, dividing by 57.3 provides an approximate radian measure.
  • Familiarity with TI-83 Plus graphing calculator functions
  • Understanding of angle measurement units (radians and degrees)
  • Basic knowledge of trigonometric functions (sine, inverse sine)
  • Ability to navigate calculator menus and modes
  • Explore the TI-83 Plus manual for detailed instructions on mode settings
  • Learn about trigonometric function applications in angle conversions
  • Research other graphing calculators and their conversion capabilities
  • Practice converting angles using both manual methods and calculator functions
Students, educators, and anyone using the TI-83 Plus for mathematics, particularly in trigonometry and angle conversions.
vertciel
Hello everyone,
I use a TI-83 Plus and I'd like to know if there is a quick way to convert an angle from radian to degree and vice versa. I am not referring to multiplying by (pi/180) or (180/pi).
Thanks!
Mathematics news on Phys.org
hit mode, it's at the top next to the 2nd button, and switch from radian to degree.
Thanks for your reply.
I actually wanted to ask whether the graphing calculator can convert a number to either radians or degrees. For example, if I typed in 145, would it be possible to press a few buttons to get the equivalent radian measure?
You have already mentioned one way of doing it, and matticus posted another. Here's another way: Divide by 57.3 (approx.). [This is essentially the same as multiplying by pi/180]
If your mode is set to radians
type in your angle in degrees and then go to angle -> the degree symbol and I think it outputs the answer in radians
If your mode is set to degrees
tyoe in your angle in radians to go to angle -> the radian symbol (little "r") and I think it outputs the answer in radians
Here's the "hard way"! To convert degrees to radians, set the mode to "degrees", and take the sine of the number. Now set the mode to "radians" and take the inverse sine!
  • · Replies 16 ·
  • · Replies 19 ·
17K
