Radiation Pressure Force on Earth
1 reply · 5K views
sharrington3
The intensity of sunlight reaching the Earth is [tex]1360 \frac{W}{m^2}[/tex].
a.) Assuming all sunlight is absorbed, what is the radiation pressure force on the earth? Give your answer in Newtons. [tex]F_r=[/tex]
b.) Give your answer as a fraction of the suns gravitational force on the earth. [tex]\frac{F_r}{F_g}=[/tex]
Intenisty is given by [tex]I= \frac{P}{A}[/tex] where P power and A is the cross sectional area.
Force is given by [tex]F=\frac{P}{c}=\frac{IA}{c}[/tex] where c is the speed of light in a vacuum.
I solved the first part correctly, no problem. I got that the radiation pressure force was [tex]5.78*10^8 N[/tex]
For the second part, I simply divided this number by the gravitational force of the sun on the earth, which I found to be [tex]F_g=3.53*10^{22} N[/tex]
When I divided these two numbers, I got [tex]\frac{F_r}{F_g}= 1.64*10^{-14}[/tex] which of course should have no units. However, the problem asks for units, so I put in Newtons anyways, and I was told the my answer must have dimensions of percent (I wasn't aware a unitless quantity had dimensions). So, I slapped in % sign. I was then told to try again; that I was wrong. What am I missing?
