Radius of Convergence of power series anx^n^2
The discussion focuses on determining the radius of convergence for the power series \(\sum a_n x^{n^2}\) and \(\sum a_n x^{2n}\) given an initial radius of convergence \(R\) for \(\sum a_n x^n\). The radius of convergence for the series \(\sum a_n x^{2n}\) is established as \(R_2 = \sqrt{R}\). For the series \(\sum a_n x^{n^2}\), the analysis leads to the conclusion that the radius of convergence \(R_1\) must satisfy \(|x| < 1\), indicating that the series converges only for values of \(x\) less than 1.
  • Understanding of power series and their convergence properties
  • Familiarity with the radius of convergence theorem
  • Knowledge of the Root Test for series convergence
  • Basic calculus concepts, including limits and supremum
  • Study the application of the Root Test in detail
  • Explore the implications of the radius of convergence theorem
  • Investigate the behavior of power series with varying exponents
  • Learn about convergence tests for series beyond the Root Test
Mathematicians, students studying advanced calculus, and anyone interested in the convergence properties of power series.
looserlama
Suppose that the power series \sumanxn for n=0 to n=∞ has a radius of convergence R\in(0,∞). Find the radii of convergence of the series \sumanxn2 from n=0 to n=∞ and \sumanx2n.
Radius of convergence theorem:
R = 1/limsup|an|1/n is the radius of convergence of the series \suman(x-c)n
Root Test:
Let L = limsup|an|1/n, then
If L<1, the series \suman converges absolutely
If L>1, the series diverges
If L=1, then the test is inconclusive.
So we know that limsup|an|1/n = \frac{1}{R}.
So for the second series (\sumanx2n) I think this is easy:
limsup|an|1/n|x|2n/n = limsup|an|1/n|x|2 = |x|2/R < 1 So that the series converges
Therefore, |x|2 < R \Rightarrow |x| < \sqrt{R}
So R2 = \sqrt{R} (Where R2 is the r.o.c. of the second series)So I tried doing this with the first series, but it doesn't work.
So then I showed that limsup|bn|1/n2 < 1 implies that \sumbn from n=0 to n=∞ converges absolutely (basically a modification of the root test)
So then if I use this for the first series:
limsup|an|1/n2|x|n2/n2 = limsup|an|1/n2|x| < 1 So that it converges.
Therefore |x| < 1/limsup|an|1/n2 = R1
But I'm assuming they want it in terms of R, so this doesn't really work...
I feel like I'm close I'm just missing something?
Any help would be greatly appreciated.
I'm a little bit dubious about some this, and I think you meant your initial series to be a_n*x^n, not a_n*x^(n^2), but let's assume all of your limits exist. In the x^(2n) case you got |x|^2<R. In the x^(n^2) case you will get limit n->infinity |x|^n<R. What does that tell you about radius of convergence?
How can we have |x|^n <R if n->infinity?
Wouldn't it be 1/R*limsup|x|^n <1 ?
So limsup|x|^n < R and wouldn't that only be true for |x| < 1 ?
Yes, I think you need |x|<1.
Oh ok, it just doesn't seem like a very formal way of showing it. Is there not a better way of doing it?
Pick a number b such that |b|<1 and apply the root test to a_{n} b^{n^2}. Now do the same for |b|>1.
  • · Replies 22 ·
