Raising and lowering indices in Linearized theory
  • Thread starter Thread starter zn5252
    Indices Theory
In linearized theory, the metric tensor is expressed as gαβ = ηαβ + hαβ, but confusion arises when trying to reconcile this with the equation gθλ = ηθλ - hθλ + O(h2). The discussion emphasizes that raising and lowering indices is a convention using the metric tensor, which must maintain its role as the inverse matrix. The relationship between covariant and contravariant tensors is crucial, as it requires the inverse property of the metric tensor to hold true. Ultimately, understanding these conventions and their implications is essential for clarity in tensor operations within the theory.
zn5252
Hi there,
in Linearized theory we know that :
gαβ = ηαβ + hαβ
If I multiply out both terms by ηθαηλβ, wouldn't one get :
gθλ = ηθλ + hθλ ? EQ1
But we already know gθλ = ηθλ - hθλ + O(h2) EQ2
How can we reconciliate EQ1 and EQ2 ? Was it an error to have raised the perturbation h with the η ?
Can we also say that gθλ = gθλ ?
I'm a bit confused.
Thanks,
zn5252, There are covariant tensors and contravariant tensors, and it's just a convention that we use the metric tensor to associate one with the other. That is, if Bμ = gμνAν, its a convention to say that A and B are the 'same' tensor. For this to work you must be able to reverse the process and say Aν = gμνBμ, and this requires gμν to be the inverse of gμν, matrixwise, that is, gμνgνσ = δμσ.
In linearized theory, gμν = ημν + hμν. Writing this as a matrix equation, g = η + h, the inverse is g-1 = (η + h)-1 = η - ηhη + ... So again it's a helpful convention to raise and lower indices in the flat space using the flat space metric ημν and its inverse ημν, but the original definition of gμν as the inverse matrix of gμν must be kept.
Remark : The product of the covariant g with its contravariant counterpart is assured to equal the unit tensor to first order In this case. See footnote of Landau & Lifgarbagez page 350.
Thanks Bill . I'm just trying to convince the little mathematician in my head ...
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 17 ·
  • · Replies 22 ·
13K
