Random Variable Measurability w.r.t. Sigma Fields
16 replies · 7K views
empyreandance
Hello everyone,
I'm having a little trouble with a probability problem with three parts; I think I'm having trouble wrapping my head around just what's going on here. If anyone could give me a starting point, I'd appreciate it.
Here's the problem (Billingsley 5.1) (X a random variable)
a. Show that X is measurable w.r.t. the sigma field J iff sigma(X) is a subset of J. Show that X is a measurable w.r.t. sigma(Y) iff sigma(x) is a subset of sigma(Y)
b. Show that if J = {empty set, omega}, then X is measurable w.r.t. J iff X is constant.
c. Suppose that P(A) is 0 or 1 for every A in J. This holds, for example, if J is the tail field of an independent sequence, or if J consists of the countable and cocountable sets on the unit interval with Lebesgue measure. Show that if X is measurable w.r.t. J, then P[X=c] = 1 for some constant c.
Thanks for any and all help!
Best regards
Did you see topology already?? The techniques used here ressembles the techniques in topology.
Anyway, for (a), you need to prove that if X is measurable, then [itex]\sigma(X)[/itex] is a subset of J.
So, firstly, how is [itex]\sigma(X)[/itex] defined?
Hello,
I thought there might be some sort of topological argument, but the book is very analysis-oriented, so I was trying to stick to that line of thinking. σ(X) is defined as the smallest sigma field that X is measurable w.r.t., i.e. the intersection of all such fields.
empyreandance said:
Hello,
OK, so [itex]\sigma(X)[/itex] is the smallest sigma field such that X is measurable. Doesn't that make it easy to show that [itex]\sigma(X)\subseteq J[/itex]?? X is measurable w.r.t. J after all...
Ah yes, of course it does. I'm not sure why I missed that. Thanks. As for the other parts, any suggestions?
For the reverse, you know that [itex]\sigma(X)\subseteq J[/itex]and that [itex]\sigma(X)[/itex] makes X measurable. You need to show that J makes X measurable. So by going to a finer sigma field, you preserve measurability. That shouldn't be too difficult?
No, it's not bad at all. It's more parts b and c that I remain a bit lost on
OK take X to be measurable wrt the trivial sigma field. We wish to prove that X is constant.
What is [itex]\{X=c\}[/itex] for each c in [itex]\mathbb{R}[/itex]?? A measurable set w.r.t. the trivial sigma field,right?? What can you deduce?
Yes, definitely measurable. Oh! If X is not constant, then the inverse image maps to a set strictly smaller than the space, or am I completely confused now? My apologies, for some reason I'm having particular difficulty on this one.
OK, [itex]\{X=c\}[/itex] is a measurable set wrt to the trivial sigma-algebra. But the trivial sigma-algebra only has two measurable sets: [itex]\emptyset[/itex] and [itex]\Omega[/itex].
So what are the only possibilities for [itex]\{X=c\}[/itex]??
Ah, either the empty set or the entire space. So, for {X=C} to be measurable it either has to be the empty set or omega.
Yes! And what does it mean that [itex]\{X=c\}=\Omega[/itex]??
It means the set of x in omega s.t. X(x) = c is the entire space, correct?
So, if [itex]\{X=c\}=\Omega[/itex], then the function is constant, right??
What you have proven is that either [itex]\{X=c\}[/itex] is empty or is omega. If there is a c such that [itex]\{X=c\}[/itex], then you're done.
Now prove that there must exist such a c. Hint: what is [itex]\{X\in \mathbb{R}\}[/itex]??
Yes, the function is assuredly constant. X in R is the set of omega such that X(w) is in R. However, X is a random variable, so it maps from the the space to R. So, I feel the connections starting to coalesce in my head... I think now, Since J is the empty set or the whole space and we've shown that either {X=c} is empty or is omega, then since X in R is the set of omega such that X(w) is in R, which should be the entire space. Then, since if a X(y) = d, whereas X(x) = c elsewhere, both these sets would map back to sets strictly smaller than the space, but strictly larger than the empty set by the way they're defined, yes?
Awesome, I can't thank you enough for both your help and patience!
