What Is the Probability Distribution Function After Four Steps in a Random Walk?
The discussion focuses on determining the probability distribution function (pdf) for a particle's position after four steps in a random walk along the x-axis. It clarifies that the binomial distribution formula, typically used to calculate the number of successes, must be adjusted to reflect the relationship between the number of positive steps (k) and the final position (w). Specifically, the correct expression for the pdf is P(ending at w) = {{n}\choose{k}} p^k (1-p)^{n-k}, where k is defined as (n+w)/2, ensuring that n+w is even. The conversation emphasizes the importance of correctly interpreting k in relation to the possible outcomes, which range from -4 to 4 after four steps. Ultimately, the thread highlights the need for a proper understanding of how to apply the binomial distribution in this context.
showzen
Suppose a particle moves along the x-axis beginning at 0. It moves one integer step to the left or right with equal probability. What is the pdf of its position after four steps?
2. Homework Equations
Binomial distribution
##P(k) = {{n}\choose{k}} p^k (1-p)^{n-k}##
In this case, ##p=0.5## and ##n=4##, so
##P(k) = {{4}\choose{k}}\frac{1}{16}##
But this is intuitively wrong, as ##P(0)## should be maximum, but here ##P(0) = \frac{1}{16}##. What am I missing here? Thank you.
I think you are on the right track, but:
What are the possible outcomes?
What does k stand for? And how does it relate to the possible outcomes?
That's is not exactly the right formula. How do you plug in negative numbers to it? For 4 steps, it is easy enough to work out by hand what the probability of each outcome is. You should start to see a pattern after doing 3 or 4 steps.
Likes whitsona
That's true scott, but if there were more steps, that would become harder.
His basic idea is sound, so long as he applies it correctly. Then he will be able to use the maths to quickly answer bigger cases.
Likes whitsona
Yes, but how do you plug in ##{{4}\choose{k}}## when k is negative?
And it needs to account for "missing numbers", like on even turns, only even outcomes are possible. On odd turns, you can only have odd results.
That's what I meant about the formula is not exactly right. You need to somehow get k to be from 0 to n, and have a formula of how that k relates to the actual number results.
Outcomes are [-4,4].
The variable k is the number of successes. Let's define success as +1 on the x axis.
The relation between k and the outcomes...
k=0 gives the outcome -4,
k=1 gives the outcome -2,
k=2 gives the outcome 0,
k=3 gives the outcome 2,
k=4 gives the outcome 4.
So ##P(w) = P(2k-4)##?
Well you don't plug negative numbers into k.
k does not represent the position on the line. It represents something else, which maps to positions.
If you take a more common situation where we use binomial distribution to calculate the probability of outcomes, like rolling a dice, ## P(3)= {{n}\choose{k}} p^k (1-p)^{n-k} = {{4}\choose{3}} (\frac 1 6)^3 (1-\frac 1 6)^{4-3}## , does not represent the probability of rolling a 3 in 4 tries, rather the probability that out of 4 tries you will get your chosen number 3 times.
The binomial distribution is the distribution of the number of positive steps, not the distribution of the final position.
Likes scottdave
Yes, I'd be happy with that. I might choose to say it a little differently, but then I'm always a bit verbose!
The variable k is the number of successes. Let's define success as +1 on the x axis. Yes
The relation between k and the outcomes... Yes
I guess w is the outcome in the list. So w=2k-4 and k = (4+w)/2
So ## P(ending \ at \ w) = {{n}\choose{k}} p^k (1-p)^{n-k} \ where \ k = \frac {(4+w)} {2} ##
And actually I'm regretting my careless use of the word "outcomes", because I think Ray's use for the number of positive steps is more appropriate.
This problem had 4 steps with equal probability. So in general with ##n## steps and ##p## probability, we have ## P(ending \ at \ w) = {{n}\choose{k}} p^k (1-p)^{n-k} \ where \ k = \frac {(n+w)} {2} ##?
Yes, as long as n+w is even.
If it takes k steps in the w direction from the origin then it takes n-k steps the other way. To end at w we need k-(k-n)=w. The k towards w can be any of the n.
  • · Replies 16 ·
