What Are Rank and Bases in Linear Algebra?
The discussion focuses on the concepts of rank and bases in linear algebra, specifically addressing how to determine the bases for the row space (rowA) and column space (colA) of a matrix A. The method described involves converting matrix A to row echelon form (U), where the non-zero rows represent the basis for rowA, and the columns with leading non-zero values correspond to the bases for colA. Additionally, it is established that a basis is a linearly independent spanning set, and the rank of a matrix is defined as the number of linearly independent rows or columns, with the rank of a full matrix being equal to the minimum of the number of rows and columns.
  • Understanding of linear independence and spanning sets
  • Familiarity with matrix operations, specifically row echelon form
  • Knowledge of vector spaces and subspaces
  • Basic concepts of determinants and matrix rank
  • Study the process of converting matrices to row echelon form using Gaussian elimination
  • Learn about the properties of vector spaces and their dimensions
  • Explore the relationship between rank and determinants in square matrices
  • Investigate the implications of linear independence in higher-dimensional spaces
Students and educators in mathematics, particularly those studying linear algebra, as well as data scientists and engineers working with matrix computations and vector spaces.
dekoi
I'm finding it difficult to grasp the concept of rank (more specifically, of bases).
First of all, what excactly is a basis? The textbook definition doesn't suffice.
What is "column space" (colA) and "row space" (rowA)?
If I am given a matrix A and told to find the bases for rowA and colA, how do i go about doing this? At first i thought of doing the following: convert A --> U (row echelon form); the non-zero rows is the basis for rowA and the columns with non-zero leading values correspond to the columns of A which are the bases for colA. Am i right? And if i am, why am i? I really don't understand the concept.
Thank you.
A basis is a linearly independent spanning set. Which if linearly independent and spanning set don't make sense? Note the rank of a basis is always the number of elements in the basis, since they are linearly independent.
The column space is the subspace of R^n that the columns viewed as vectors in R^n span. Similarly the row space.
Row, or column echelon form works nicely to find the span: you're not altering the span by combining rows, row echelon form just happens to be a really nice combination where it is clear what the span is because of all the zeroes lying around.
I mean if i asked you what the span of (1,3,4) (2,3,1) ans (1,2,3) is you couldn't say of the top of your head, but put them as rows of a matrix and do row ops and it becomes clearer (I won't do it because it is a pain to typset), but suppose the rows came out as (1,0,0), (0,1,0) and (0,0,1) then clearly these vectors span all of R^3, don't they. EMPHASIS: I do not know this happens, I picked them at random.They might come out as (1,0,0) (0,0,1) and (0,0,0) but then its easy to see they span a 2-dimensional subspace.
A basis is basically a minimal spanning set (which automatically has to be linearly independent). Any set that spans the space will have cardinality equal or greater than the basis. Of course there are concepts of finitely generated spaces (spaces that have a basis with finite cardinality R^n where n is finite) and infinitely generated spaces (the other way round, example- R^infinity)
A basis of a space need not be unique.
This is easy to see. Take a basis, and add one element to all the others. Since they are linearly independent, this new set will also remain linearly independent, and will have the same cardinality as the basis (since you're not adding newer elements) and ... lots of things to be proved, great, easy to grasp results...
the rank of a matrix as the number of linearly independent rows or columns. Also note that all zero matrices have rank = 0. The rank of a (m*n) matrix is equal to the rank of the largest sub matrix with a determinant different from zero.
A full matrix is matrix with rank equal to min( n(rows), n(cols)). only a full matrix is non-singular. If a matrix is not full, then it is easy to see that it can be transformed to a matrix with atleast one row/col of zeroes, which obviously makes it singular. (of course, singularity and stuff are defined where applicable only i.e in square matrices)
