What is the rank of the SU(2)xSU(2) algebra?
  • Context: Undergrad
  • Thread starter Thread starter gentsagree
    Algebra rank So(3)
The rank of the SU(2)xSU(2) algebra is determined to be 2, as it consists of two SU(2) components, each contributing a rank of 1. The discussion clarifies that the rank corresponds to the number of mutually commuting generators, which in this case are J_3 and K_3, both of which can be simultaneously diagonalized. The Casimir operators for this algebra can be inferred from the commutation relations, confirming that there are two distinct Casimir operators corresponding to the two SU(2) factors.
  • Understanding of Lie algebras and their commutation relations
  • Familiarity with Casimir operators and Racah's theorem
  • Knowledge of Cartan subalgebras and their dimensions
  • Basic concepts of SU(n) groups, particularly SU(2) and SU(3)
  • Study the commutation relations of SU(2) and SU(3) in detail
  • Learn about the construction and significance of Casimir operators in Lie algebras
  • Explore the properties of Cartan subalgebras and their role in determining rank
  • Investigate the structure and rank of the proper orthochronous Lorentz group, SO(3,1)
Mathematicians, physicists, and students studying group theory, particularly those focusing on Lie algebras and their applications in theoretical physics.
gentsagree
I am reading in my group theory book the well known commutation relations of the Lie algebra of SO(3), i.e. [J,J]=i\epsilon J.
What I don't understand is the statement that "from the relations we can infer that the algebra has rank 1".
Any ideas?
The rank of a Lie Group is the maximum number of its mutually commuting generators..In other words it's how many Casimir operators you can construct (Racah's theorem)... for SO(3) that's 1 because if you take J_1, J_2, J_3 they don't commute with each other. The Casimir operator is the J^2 = J_1^2 +J_2^2 +J_3^2 which commutes with the generators J_i: [J_i, J^2]=0
Thank you very much, very clear. So, I suppose there is a way to find out how many Casimir operators I can construct, given an algebra with its commutation relations. I know SO(3) has J^2, but it is not clear to me how I know that it is the only Casimir there is.
Also, the rank of the Lie group corresponds to the rank of the Lie algebra, which is given by the dimension of the Cartan subalgebra (as you said, the number of mutually commuting group generators); so which is the one element of the dimension-1 Cartan subalgebra here? Is it correct to think that the Cartan is of dimension 1 since each generator commutes only with itself?
how many elements does the Cartan subalgebra of SU(3) have?
Ok, what I said above was correct; I see now that from the commutation relations there are no commuting generators, but I can always pick one at random and see that it commutes trivially with itself. This is one way to see that the rank is 1. And from this I can infer there will be only one Casimir by Racah's theorem.
Why the reference to SU(3) ?
because I think that the Cartan subalgebra of SU(3) is not of dimension 1.
Sure, the rank of SU(3) is 2, so is the dimension of the Cartan subalgebra. There one could see more clearly from the (modified) commutation relations that there are indeed two commuting generators.
ΟΚ then, it seems I misunderstood what you meant with this:
I see. Thanks for the help anyway.
Ok, I think I confused myself again. I thought I was thinking about this the right way, but I can't apply my reasoning to a slightly harder case: the proper orthochronous Lorentz group, SO(3,1), or equivalently, SL(2,C).
Here the commutators read<br /> \begin{split}<br /> [J_{i}, J_{j}] &amp;= i\epsilon_{ijk}J_{k} \\<br /> [K_{i}, K_{j}] &amp;= i\epsilon_{ijk}J_{k}\\<br /> [J_{i}, K_{j}] &amp;= i\epsilon_{ijk}K_{k}<br /> \end{split}<br />
and my book says very confidently that from these I can read off that the rank of the algebra is 2. And there is no way I can think of in which I can see it. I don't see any commuting generators, apart from the trivial case where each specific generator, eg J_{1}, commutes with itself.
First a fast investigation: the generators of the sl(2,c) are for exaple the pauli matrices and the identity matrix... In fact any complex matrix 2x2 can be written as a linear combination of those four:
M = a_0 I_2 + \sum_{i=1}^3 a_i \sigma_i
Obviously you can simultaneously diagonalize the \sigma_3 and I_2, so it's rank 2...
Now in the case of the su(2)x su(2)
I am pretty sure that taking J_3,K_3 as the diagonalizable matrices.
So the \{J_3,K_3\} (not anticommutation) is a set of mutually commuting/simultaneously diagonalizable generators?
In fact this is like have 2 SU(2)s, so the rank you'd expect is 1 ( either because SU(2) is pretty much like SO(3) or by checking out the commutations each has 1 diagonalizable generator per time which we choose by convention the 3rd J3 ) from each, sum=2.
Would it be easier for you if you tried to define K^{\pm}=c( K_1 \pm i K_2 ), J^{\pm}=c(J_1 \pm iJ_2) and K_3,J_3?
