Rate of change from 1 to 2 for f(x)=2x^3 + x
The discussion revolves around finding the average rate of change of the function f(x) = 2x^3 + x from the interval [1, 2]. Participants are exploring the correct application of the average rate of change formula and addressing confusion regarding the function's components.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants attempt to apply the average rate of change formula but express confusion about the function's terms and the correct calculations. Some question the interpretation of the formula and the role of each term in the function.
The discussion is active, with participants providing guidance on the correct formula and calculations. There is a mix of understanding and confusion, with some participants clarifying their approaches while others continue to seek clarification on specific steps.
Some participants express uncertainty about handling the additional term "+x" in the function, which contributes to the confusion regarding the calculations. There are indications of varying levels of understanding of the average rate of change concept.
Rusho
Find the average rate of change from 1 to 2 for the function f(x)=2x^3 + x
so I did this:
[f(2) – f(1)] – [2x^3 + x] / 2-1
= 2-1-2x^3 + x / 1
= 1-2x^3 + x
= -2x^3 + x
Right?
The average rate of change of f from a to b is
[f(b)-f(a)]/(b-a)
and it's (naturally) just a number. It doesn't depend on x. Check your definition.
[2(2)^3 - 2(1)^3] - [2x^3 + x] / 2-1
16-1-2x^3 + x / 1
15-2x^3 + x
I don't understand what you are telling me
You've got the definition of the average rate of change wrong.
You wrote something like (f(2)-f(1)-f(x))/(2-1).
By definition, the average rate of change of f on the interval [a,b] is:
[tex]\frac{f(b)-f(a)}{b-a}[/tex]
So in your case, the average rate of change is:
[tex]\frac{f(2)-f(1)}{2-1}[/tex]
Ok, I am not sure what to do with 2x^3 + x . So I subtracted it from the f(b) - f(a).
If I had 2x^3 by it self, I can see just putting 2(2)^3 - 2(1)^3 / 2-1
but the "+x" is confusing me
I think I got it
2(2)^3 + x - 2(1)^3 + x / 2-1
=16-2+x+x / 1
=14+2x
=-2x + 14
x = -7
So you can solve it if the function is 2x^3, but not if it's 2x^3+x? What's the difference, conceptually?
f(x)=2x^3+x, so what is f(2)? And what is f(1)?
Rusho said:
I think I got it
=16-2+x+x / 1
=14+2x
=-2x + 14
x = -7
Calculate f(2). Calculate f(1). Subtract the result of f(1) from f(2).
The solution for f(2) is not 16+x. You have to substitute '2' for x everywhere it appears, so the solution for f(2) is 16+2.
Also, your algebra is wrong (in addition to being not applicable in this case). If you have:
[tex](3x^2 + 3x) - (2x^2 + 2x)[/tex]
then the minus sign means both the 2x^2 and the 2x are negative:
[tex]3x^2 + 3x - 2x^2 - 2x[/tex]
[tex](3x^2 - 2x^2) + (3x - 2x)[/tex]
etc.
2(2)^3 + (2) -1 / 2-1
16+2-1 / 2-1
17/1
I'm sorry if I'm just not getting it
Alright, let's take some steps back.
You are given a function f. It's a machine that eats a number and spits out a (usually different) number.
f(x)=2x^3+x tells you the value of the function at each point, it's an equality that holds for each number x.
For example:
f(1)=2(1)^3+1=2+1=3
f(5)=2(5)^3+5=2(125)+5=255
So if you want to calculate [f(2)-f(1)]/(2-1) you have to calculate f(2) and f(1). I already did f(1) for you above. Now you do f(2) and calculate [f(2)-f(1)]/(2-1)
2(2)^3 + (2) - 2(1)^3 +1 / 2-1
=18-3 / 2-1
=15/1
=15
Right that's correct.
BTW: Mind your brackets: -2(1)^3+1 is not the same as -(2(1)^3+1)
Great! Thanks for your help!
I have another one, maybe I should start a new post
  • · Replies 24 ·
