Rate of change of the area of the rebgion
The problem involves a board sliding down a wall, creating a triangular area between the board, the ground, and the wall. The specific question is about the rate of change of this area at a given moment when the board's position is defined.
  • Participants discuss the geometric relationship of the board's position and the area it creates, referencing the triangle formed. There are attempts to apply the Pythagorean theorem and derivatives to find the rate of change of the area.
Some participants are questioning the assumptions about the shape formed by the board and the ground, while others are clarifying the relationships between the variables involved. There is an acknowledgment of potential errors in the application of derivatives and variable consistency.
There is a focus on understanding how the dimensions of the triangle change as the board slides, indicating that the variables should not be treated as fixed values but rather as changing quantities throughout the motion.
fifaking7
A board 5 feet long slides down a wall. at the instant the bottom end is 4 feet from the wall, the other end is moving down the wall the rate of 2 feet per second.at that moment how fast is the area of the region between the board, the ground and the wall changing?
a=1/2bh
x^2 + 4^2= 5^2
x=3
da/dt= 1/2b(db/dt)(dh/dt)
I think i started it up wrong and I don't know where to go next..
a=1/2bh
x^2 + 4^2= 5^2
x=3
What is the shape of the region below the board and above the ground at the moment under consideration?
just a normal triangle drawn on a line like a typical triangle leaning against a wall problem.
Neither end of the board is touching the ground, so it's not a triangle.
fifaking7 said:
a=1/2bh
Have another look at that derivative. It looks like the product rule hasn't been applied properly. Also one of those b/h is x. You'll have to stay consistent with your variable names.
http://img231.imageshack.us/img231/5130/scan0060kd.jpg
that is how it looks
You're right. I misread the problem.
When you said x=3, that should be h=3 .
In general, how are b and h related, considering that they're legs of a right triangle?
i said b= 4ft and h=3 ft
That's what b & h are at the instant that h = 4 ft, but how are they related in general?
(Use the Pythagorean theorem.)
The crucial point that you seem to be missing is that you need to figure out what is happening as the board slides down the wall, so h moves from more than 3 ft to less than 3 ft (and, at the same time, b moves from less than 4 ft to more than 4 ft). When that is happening, the area of the triangle is changing, and that is what you are supposed to be reckoning. So, you need to let b and h be variables, not fixed numbers.
RGV
Of course, that's a typo !
It should have said:
That's what b & h are at the instant that b = 4 ft, but how are they related in general?
