Rate of fill of a cone-shaped fluid container
The discussion centers on the rate of fill of a cone-shaped fluid container, specifically addressing a homework problem involving fluid dynamics. The inflow rate is 600 ft³/min, while the outflow rate is 1.5 times the volume of the cone, leading to confusion about the stability of the fluid level. Participants concluded that the volume of water in the tank will stabilize at 400 units, despite initial assumptions of a non-accumulating state. The differential equation dV/dt = 600 - 1.5V was derived, confirming that the tank will eventually reach an equilibrium volume.
  • Understanding of fluid dynamics principles
  • Familiarity with differential equations
  • Knowledge of volume calculations for geometric shapes, specifically cones
  • Basic integration techniques and the chain rule
  • Study the derivation and application of differential equations in fluid dynamics
  • Learn about the behavior of systems at equilibrium in fluid mechanics
  • Explore the concept of stability in dynamic systems
  • Investigate the volume formula for cones and its implications in real-world applications
Students studying fluid dynamics, engineers working with fluid systems, and anyone interested in mathematical modeling of fluid behavior in containers.
Jerbearrrrrr
An engineer came to me with the following problem.
I'm not convinced the problem is correct - but I've probably just overlooked something, since I haven't done any vaguely practical problems in years.
Anyway, here it is.
[PLAIN]http://img526.imageshack.us/img526/1911/54308613.png
Volume of a cone, I'm guessing trivial applications of chain rule in 1D. Some integration (integrating factor at worst? Probably separable.)
Putting pi*7.5^2*30/3 (should be the volume of that cone) into google gives 1,700 or so.
So suppose the cone is almost full - then the out-flow greatly dwarfs the in-flow.
So the cone can never fill up, surely?
Indeed, the liquid level should just sit at a stable equilibrium at 400 units of liquid.
What have I missed?
The ridiculous non-SI units don't help as well.
Is the answer complex? (even pure imaginary?)
I'm having problems figuring out which parts of the problem you're doing. Are you asking about part c? The rate at which water is entering the tank is 600 ft3/min, and the rate out is 1.5 * 562.5\pi ft3/min, which as you have noticed, is much larger than the rate of inflow.
Most likely there is a typo in the problem - maybe they switched the inflow and outflow rates or got the numbers wrong somehow.
I don't see any stable equilibrium of 400 units, as you said. Every bit of water that comes in will go right out, so the tank will never accumulate any depth of water.
dV/dt := 600 - 1.5V
So dV/dt = 0 at V=400.
Some water must accumulate in the tank. Intuitively, because V=0 (initially) gives dV/dt > 0 (and we can integrate a strict inequality happily).
Maybe it's not a stable equilibrium, but won't all scenarios always end up at V=400? Like some kind of attractive point.
And yes, I apologize, I forgot to mention I was talking about part c).
(The rest is trivial, but I should have said so)
At first I thought they'd switched the inflow for outflow, but then I thought it'd be reasonable to set students a problem where the outflow depends on the weight of fluid in the container in some simple way (such that they can actually solve stuff analytically). Must be a typo of some other flavour, then.
Thanks.
Jerbearrrrrr said:
dV/dt := 600 - 1.5V
OK, I totally misinterpreted what they meant by V as the volume of the tank, not the volume of water in the tank at time t.
Solving the DE + initial condition, I get V(t) = 400 - 600e-3t/2
As t gets larger and larger, the exponential term decreases to 0, so yes, there is an equilibrium value.
23K
  • · Replies 18 ·
12K
