Solve Word Problem: 30 Persons in 4 Days = 40 Persons in x Days
  • Thread starter Thread starter alijan kk
    Word problem
The problem involves determining how many days it takes for 40 persons to complete a task that 30 persons finish in 4 days. The initial approach incorrectly suggests that more workers would lead to more time, which contradicts the principle of inverse proportionality between the number of workers and time taken. The correct method involves calculating the work rate per person and applying it to find the time for 40 workers. The relationship can be expressed as days = k/persons, where k is a constant derived from the initial conditions. Ultimately, the correct solution indicates that 40 persons would complete the task in 3 days.
alijan kk
New poster has been reminded to fill out the Homework Help Template when starting a new thread in the Schoolwork forums
A task is completed by 30 persons in 4 days. In how many days, the same will be completed by 40 persons ?
My attempt:
(30/4)/1=(40/x)/1
(30 persons per 4 days per task=40 persons per x days per task)
Doing this way i found x= 5.33 day or 5 whole days .
is this correct way of doing this problem?
My attempt:
(30/4)/1=(40/x)/1
Why would it take longer with more people working in it? Always sanity-check your answers to see if something doesn't look right...
BTW, I will move this to the schoolwork forums for you now.
My attempt:
(30/4)/1=(40/x)/1
What about if there is only 1 person? By your method, ##x = 4/30## days, which is about an hour!
Likes YoungPhysicist
You want to get it down to what each person is contributing. Then you can work with a different number of people.
So how much do those same 30 people do in 1 day? How much of the 4-day job is done after day 1?
Once you know that, how much does each person do in 1 day?
Try this!
Let’s say you alone can finish a task in two days. So if you get help from one of your friends, that task will be finished in only one day. How about four people working together? It would remain only (1/2)day. You see, the amount of days is reduced as the people increases. This case is opposite from your attempt.
As others have said, it doesn't seem logical that more people take more time to do the task. For these cases where a variable decreases when the other increases we say that they are inversely proportional.
Have a look at this functions, ##f(x) = \frac{6}{x}##, try increasing the values of ##x## and you will notice that ##f(x)## will decrease as you do so.
In your exercise, ##persons## and ##days## are inversely proportional which means that ##days=\frac{k}{persons}## where ##k## is a constant.
You already have two values, I let you do the rest ;)
The question is a constant-rates problem or exercise. Two parts in it. Descriptive part, and question part using different number of workers.
R=W/T
RATE of work is amount of work W divided by time T.
This can easily also be stated RT=W.
If all workers each work at the same rate, then R is the work rate for 1 worker, and for N workers, the algebraic formula is NRT=W.
Let's see how this goes:
The first sentence let's us say:
30r*4=1
The "1" is for those thirty persons doing ONE TASK.
The question, second sentence, let's us say:
40*r*x=1
r being the work rate of anyone person, x the number of days to do the ONE TASK.
You should be able to finish from there.
