Rational exponents (was: Math Discussion)
5 replies · 2K views
goolalklk
(-64)^(3/2)
None.
There is no answer that can be reached and it is supposed not be a real number. I was wondering why that is. How is it that there is no "real" answer to this problem?
goolalklk said:
(-64)^(3/2)
None.
##(-64)^{3/2} = [(-64)^{1/2}]^3##
Does that answer your question?
Alternatively: (−64)3/2 = √(-64)3
You're right in that there is no real solution. The square root of a negative number is an imaginary number, in which case you must use "i" to express √(-1).
i2 = -1 and √(-1) = i.
The negative sign makes it so that the stated number isn't real.
Not exactly.
Real numbers can be positive or negative. However, taking the square root of a negative number does not give a real number result. Instead, imaginary numbers were invented to overcome this problem. The imaginary unit i is defined such that i2 = -1.
