I Rational sequence converging to irrational
The discussion revolves around the lemma stating that for any irrational number, there exists a sequence of rational numbers that converges to it, based on the density of rational numbers in the reals. Participants explore various approaches to rigorously prove this lemma, including using decimal representations and topological concepts. The concept of density is clarified as the existence of rational numbers between any two real numbers. A proposed method involves defining a sequence of rational numbers that approach a fixed irrational number by narrowing down intervals. Ultimately, the conversation highlights the connection between density and the convergence of sequences in the context of real numbers.
Delta2
Homework Helper
Insights Author
In the textbook I have (its a textbook for calculus from my undergrad studies, written by Greek authors) some times it uses the lemma that
"for any irrational number there exists a sequence of rational numbers that converges to it",
and it doesn't have a proof for it, just saying that it is a consequence of the fact that ##\mathbb{Q}## is dense in ##\mathbb R##.
Any ideas how to proceed for a rigorous proof?
My idea is that if ##x=x_0.x_1x_2...x_n,...## is the representation of the irrational x in the decimal system with ##x_i \in {0...9}## then the sequence
##\sigma_n=\sum\limits_{k=0}^{n}\frac{x_k}{10^k}## is rational and converges to the number but something tells me this is not a rigorous proof.
Mathematics news on Phys.org
What does it mean, that ##\mathbb{Q}## is dense in ##\mathbb{R}##?
That for any ##a,b## reals there exists ##c\in \mathbb Q## such that ##a<c<b##.
Can you use this to find a sequence of rational numbers that converge to ##a##, if you keep ##a## fixed here?
Side remark: you should require a<b in the definition, otherwise a=2, b=1 is a counterexample.
It might be easier to use the topological approach: given ##a \in \mathbb{R}## then every open neighborhood of ##a## contains a number ##c \in \mathbb{Q}##. Now all is left, is to define the sequence ##(c_n)_{n \in \mathbb{N}}##.
That's where all my problem is to define the sequence, you got to give me as hint something more than the definition of dense. It seems there are infinitely many such sequences, got to find a way to choose one...
You certainly have a lot of choice. Just pick an element, then think about how to find another element that is closer.
Take open balls as neighborhoods and narrow down the diameter. The difficulty here is, that a hint and a solution is the same thing.
sorry can't come up with any ideas (regarding the topological approach i was really bad at Topology) other than the one based in the decimal(or any other base) representation .
##x_0=[x]##
##x_n=\frac{[10^nx]}{10^n}## where [x] denotes the integer part of x.
I think we can prove kind of easily that ##\lim x_n=x## (because ##[10^nx]=10^nx-\epsilon_n(x)## with ##0<\epsilon_n(x)<1## so that ##\frac{\epsilon_n(x)}{10^n}## converges to zero easily...
BUT the million dollar question,
"where do I need that ##\mathbb Q## is dense in ##\mathbb R##""?
(ok probably we need it for the rigorous definition of function [x]=the unique integer z such that z<x<z+1)
O.k. let's take your definition. We have two real numbers ##a## and ##b=a+\dfrac{1}{n}## for ##n \in \mathbb{N}##.
Now you said, there is a rational number ##c_n## with ##a < c_n < a+\dfrac{1}{n}##.
So does the sequence ##(c_n)_{n \in \mathbb{N}}## converge, and if, what is the limit?
Likes Delta2
I wonder why I didn't think of that, I was trying to uniquely determine ##c_n## maybe that's why.
If you want to learn more about it, you can read about the cauchy construction of ##\mathbb{R}##. Let me give you a brief sketch. Let's assume ##\mathbb{Q}## is given. I.e., we know such an ordered field exists.
Define the set ##F := \{(u_n)_n \in \mathbb{Q}^{\mathbb{N}} \mid \forall d \in \mathbb{Q^{+}: \exists n_0: \forall p,q > n_0: |u_p - u_q| < d}\}##
and the set ##N := \{(u_n)_n \in F \mid \forall d \in \mathbb{Q}^{+}: \exists n_0: \forall n > n_0: |a_n| < d\}##
While this may seem abstract, you can think about ##F## as the cauchy sequences and ##N## as the sequences converging to ##0##.
Now, you can define the equivalence relation ##\approx## on ##F##
such that ##(u_n) \approx (v_n) : \iff (u_n-v_n)_n \in N##
We then define ##\mathbb{R} := F/\approx##.
This means, we define the real numbers as the equivalence classes of sequences whose difference 'converges' to 0.
So in this context, real numbers are sets! One can prove (using denseness), that if we take any element out of this set (and such a set is never empty because equivalence classes are never empty, by reflexivity), that this sequence of rationals will converge to the real number it represents, as desired.
Likes Delta2
I would rather call it using ##\mathbb{R}## is the completion of ##\mathbb{Q}## by definition, and thus the result follows immediately from the convergence of Cauchy sequences. That was my first thought, too, but density is an unnecessary step here.
