RC circuit with 7.5 mA current source and parallel resistors
46 replies · 14K views · last reply
goonking
Circuit schematic with a 7.5 mA current source Is, resistor R1, resistor R2, capacitor C1, and a switch marked t=0; labels iC1(t) and UR1(t) shown.
so when t=0, the capacitor is a closed circuit.
The Req of the circuit is (20k)(30k)/(20k+30k)= 12000 ohms.
U = I Req = (7.5x10-3A) (12000 ohms) = 90 Volts
so there is a voltage drop of 90 volts across the 20k resistor (R1), when t=0.
RC= Req C = (12000 ohms) (0.1 x10-6F) = 0.0012 sec
∴ UR1= Uo (e-t/RC) = UR1= 90V (e-t/0.0012)Ok, so then the current flowing through the capacitor would be the same current flowing through the 30k resistor when t=0.
Using current division, 7.5x10-3A [20 / (20+30)] = 0.003 A
iC1 = io (e-t/RC) = (0.003A)(e-t/0.0012)
This is my final answer, I've erased my initial attempt as it was wrong. Could someone verify if this is correct?
goonking said:
Circuit schematic labelled Fig. 3: a current source Is in parallel with resistor R1 and a switch at t=0 leading to capacitor C1 in series with resistor R2, with current iC1(t) and voltage UR1(t) marked.
So when the switch is closed, it becomes a dc circuit, and under dc conditions, we replace each capacitor with an open circuit:
https://www.physicsforums.com/attachments/101015
Now all the current from the source is going through the 20k ohm resistor, so the voltage drop there is
I R = (0.0075 A) (20,000 ohm) = 150 V
since the capacitor is in parallel with the 20k ohm resistor, the voltage drop on it also is 150 V
Therefore, Ucapacitor = ε [ 1 - e-t/RC]
but ε = I R = (0.0075 A) (20,000 ohm) = 150 V
and RC = (20,000Ω) (0.1x10-6F) = 0.002
∴ Ucapacitor = (150) [ 1- e-t/0.002]
The capacitor is initially uncharged. The voltage across it is zero at t=0. That's like a short circuit, not an open circuit.
If it is a short circuit, then my drawing is wrong? :(
So a capacitor only behaves as a open circuit when it is fully charged?
Yes. This is when current ceases to flow through the capacitor, like the case for an open circuit.
Using current division, 7.5x10-3A ( 20 / (20+30)) = 0.003 A
RC = (30,000)(0.1 x 10-6) = 0.003 seconds
iC1 = io (e-t/RC) = (0.003A)(e-t/0.003)
or is RC not 0.003 because I had to use Req of the circuit before capacitor became fully charged?
assuming this is correct, my answer to the previous post should be:
This means voltage across R1 is exponentially decreasing. Is it? Think about the steady state of this circuit. Which quantities become zero in the steady state here?
so the capacitor has increasing voltage across it over time, and decreasing current across it, so when current decreases, R2 will have less current passing through it... and since we have a current source, we have a constant flow of current flowing through it, therefore all the current (or most) overtime will have to flow through R1 once the capacitor is fully charged (where it becomes open circuit)
applying ohms law, the voltage drop across R1 should be increasing.
Yeah... I'm having a harder time understanding/remembering the equations than understanding the concepts. :H
The voltage drop across R1 should be (7.5 mA) (20k ohms) = 150 V.
but I'm having trouble obtaining an equation that equates to 150V when t → ∞
goonking said:
so the capacitor has increasing voltage across it over time, and decreasing current across it, so when current decreases, R2 will have less current... and since we have a current source, we have a constant flow of current, therefore all the current (or most) overtime will flow through R1...
Right. Have you studied source transformation? It would be easier.
No, I'm in an intro class, and we haven't even (or just started) AC circuits.
Ok but source transformation means converting current source into voltage source.
You can replace a current source of magnitude I with parallel resistance R with a voltage source of magnitude I*R with the same resistance R in series. This way, you'll end up with a simple RC circuit with two resistors in series with a capacitor and a voltage source.
Source transformation diagram: on the left, a voltage source Vs in series with resistor R; on the right, a current source Is in parallel with resistor R; a double-headed arrow between them is labelled Vs = Is R.
Initial current through the capacitor will be 30mA and that through R1 is 20mA, as you calculated earlier. Now, voltage across R2 decays to 0 exponentially and voltage across R1 increases to 150V exponentially. Also, capacitor voltage increases exponentially to 150V. Using the source transformation, you'll get the expression for ic(t). You can use it in the original circuit to find i1(t) and U1(t).
I'm trying to answer it without using source transformation, I know it'd be easier but we haven't covered it yet in class.
Ok. How about Thevenin's theorem? Have you covered it yet?
UR1(t) = [Is - IC1(t)]/ 20kΩ
Plugging in IC1(t)] from what I found before:UR1(t) = [Is - io (e-t/RC) ]/ 20kΩ = [Is - (0.003A) (e-t/0.0012) ]/ 20kΩ
Nope. we are low on options haha, sorry.
This is the right expression.
Edit: Oh dear! How did I miss that..:-p V=IR and not I/R...
The time constant is incorrect.
I didn't derive this equation, I just thought for a bit and this equation made sense.
How would one derive this?I wasn't sure if I had to use the resistors of R2 (the resistor it was in series with, so they have the same current) or Req of the circuit when the capacitor was short.
would I be wrong if I said Time constant for a circuit = (Req) (Ceq)? (assuming there were more than 1 capacitor)
No. The time constant considers both R1 and R2. How are they connected when you open the current source?
the capacitor, and both resistors would be in series.
Right! So what would be your time constant?
it would be the Req of the two resistors.
but in this case, the R in time constant = RC is 30,000 ohms? because it is in series with the capacitor, thus having the same current as the current flowing through the capacitor.
But the current (and rate of change of current)through the capacitor also depends on R1. Change R1 and verify. Current division changes with R1. Voltage across the capacitor also depends on R1. Also, using source transformation, the circuit will look like this:
150V source in series with 20k and 30k and the capacitor. This means R1 and R2 are in series when it comes to time constant calculation. Open the current source and short the voltage source and see how the elements are connected.
No. That's right!
cnh1995 said:
No. That's right!
So what equations did you get for U1(t) and Ic(t)?
iC1(t) = io (e^-t/RC) = (0.003A)(e^-t/0.003)U1(t) = [Is - iC1(t)] 20k
Req=50k as discussed earlier..
when the capacitor is short, the Resistors are in parallel so the Req is 20x30 / 50 = 12k ohms.
when the capacitor is fully charged, and is open, only R1 has current flowing through it, so Req is just 20k ohms.
I'm still having trouble understanding if the R in RC equal to the Req when t=0 or when the capacitor is fully charged.
The only way Req would be 50k if is the 2 resistors are in series, and that is only possible when the current source is open, but the question doesn't state the current source is disconnected after the capacitor is fully charged.Unless I'm misunderstanding something, I'll reread the past posts again.
Ok. It would be clearer once you try it using source transformation or Thevenin's theorem, after you cover them in the class.
