Reaction force on disk by pivot
The problem involves a uniform disk of mass M and radius R, pivoted at a point on its edge. The disk is released from rest when its center of mass is at the same height as the pivot, and the discussion focuses on determining the reaction force exerted on the disk by the pivot at two specific instances: when the disk is released and when it is at its lowest point.
  • Mixed
  • Participants explore the forces acting on the disk, including the reaction forces in both x and y directions, and question the relationship between these forces and the disk's motion.
  • Some participants attempt to apply Newton's laws and discuss the implications of torque and angular acceleration, while others express confusion about how to relate these concepts to the reaction forces at the pivot.
  • There is a discussion about the tangential and radial accelerations at different points in the disk's motion, particularly questioning their values at the moment of release and at the lowest point.
  • Some participants suggest drawing free body diagrams to clarify the forces and torques acting on the disk.
The discussion is ongoing, with participants sharing their thoughts and attempts to understand the problem. Some guidance has been offered regarding the application of Newton's laws and the relationship between forces and torques, but there is no explicit consensus on the solution or the values of the reaction forces at the specified instances.
Participants note that the problem was encountered in an exam context, and there is frustration regarding the lack of provided solutions or answers from the professor. This has led to uncertainty about the correctness of their approaches and reasoning.
noob314
A uniform disk of mass M and radius R is pivoted about a point on its edge. The disk is released from rest when its center of mass is at the same height as the pivot. What is the reaction force exerted on the disk by the pivot the initial instant the disk is released? The instant the disk is at its lowest point?
[tex]I_{of disk, CM}= \frac{1}{2}MR^{2}[/tex]
Instant disk is released
I'm guessing [tex]\Sigma \vec{F}_{x} = 0[/tex] and since there are no horizontal forces acting on the disk, the reaction force of x ([tex]R_{x}[/tex]) = 0.
It looks like there are forces acting on y, so [tex]\Sigma \vec{F}_{y } = Mg + R_{y}[/tex]. Since it is not in a static equilibrium,[tex]\Sigma \vec{F}_{y }[/tex] is not 0. That's where I'm stuck. My textbook doesn't have anything about reaction forces, and my lecture only covered reaction forces in static equilibriums.
Instant disk is at its lowest point
I don't know how to start on this one. Obviously there is some force going towards the left. There is probably radial acceleration at the bottom, but I'm not sure about tangential. Since the tangential acceleration is going towards the left before it reaches the lowest point, would the tangential acceleration be 0 at the lowest point and then towards the right once it passes it?
I am sure your textbook mentions somewhere (in one form or another) that action is equal and opposite to reaction and calls this Newton's Third law. So the reaction force exerted by the disk on the pivot is equal and opposite to the action force exerted by the pivot on the disk. That force has two components, call them Fx and Fy. Draw a standard free body diagram and say that
Fnet,x = max
Fnet,y = may
τNet=Iα
Obviously, torques and the moment of inertia are to computed with respect to the pivot.
The tangential acceleration is zero when the net torque is zero.
The radial acceleration is zero when the center of mass moves in a straight line.
I'm starting to get frustrated. This was on an exam, but my professor refuses to give out the solutions or even the answers, so I can't even check if I'm close to the answer. This looks like it's suppose to be simple, but I'm just not getting it.
For the instant the disk is released
[tex]\Sigma \vec{F}_{x} = Ma_{x} = 0[/tex] with [tex]\vec{F}_{r, x} = 0[/tex] I'm assuming [tex]a_{x}[/tex] would be the radial acceleration, which would be 0 because the object would still be at rest, correct?
[tex]\Sigma \vec{F}_{y} = Mg + R_{y} = Ma_{y}[/tex] So in this case, would [tex]a_{y}[/tex] be the tangential acceleration?
For the instant the disk is at lowest point
Would the radial acceleration be 3g/2?
[tex]a_{r} = R\omega^{2}[/tex]
[tex]U_{i} = K_{f}[/tex]
[tex]= MgR = \frac{1}{2} I\omega^{2}[/tex]
Because the pivot point is not at the center of mass, the parallel axis theorem would be used.
[tex]= MgR = \frac{1}{2}(\frac{1}{3}MR^{2}+MR^{2})\omega^{2}[/tex]
[tex]= MgR = \frac{2}{3}MR^{2}\omega^{2}[/tex]
[tex]= \frac{3g}{2} = R\omega^{2}[/tex]
[tex]a_{r} = R\omega^{2} = \frac{3g}{2}[/tex]
I'm still confused as to whether the angular acceleration or net torque would be equal to 0. In order to find the angular acceleration, I need to find the net torque and vice versa, but I don't know how to find either at the lowest point.
As soon as the disk is released, the forces at the pivot generate no torque about the pivot. The only torque is generated by gravity. To find this torque, you need to find where it is applied with respect to the pivot. Can you tell where the external force of gravity acts on the disk?
Well, the torque from the external force of gravity would act on the center of mass of the disk, which is distance R from the pivot. That would give me to net torque on the object which would allow me to find the angular acceleration, and then the tangential acceleration. But I still don't see how that will help me find the reaction force or the radial acceleration.
Read posting #2. You have three equations and three unknowns, the acceleration and the two reaction forces. The radial acceleration is zero instantaneously as soon as the disk is released but the tangential acceleration is not. You can find the tangential acceleration from the angular acceleration. Once you know that, you can find the vertical reaction force. The horizontal force is (instantaneously) zero as soon as the disk is released.
You are on the right track for part (b) except that the moment of inertia of a disk about its CM is not (1/3)MR2.
Thanks, I understand it now.
