Reading CG Tables: An Idiot-Proof Explanation
  • Thread starter Thread starter skrat
    Reading
The discussion centers on understanding Clebsch-Gordan (CG) coefficients and how to read them from provided tables. The user initially struggles with the notation and the correct application of the coefficients in quantum mechanics, specifically when adding angular momenta. Clarifications reveal that the coefficients are derived from the inner products of basis states, and the user learns to correctly identify the relevant entries in the CG table. The importance of following the triangle rule for angular momentum is emphasized, and the user ultimately gains clarity on the notation and structure of the CG tables. The conversation highlights the complexity of these tables and suggests alternative resources for easier understanding.
skrat
Ok, this my not be appropriate topic to post my question but it is related to QM (moderators, feel free to move the thread if needed). I don't have any calculations nor do I have anything interesting to write. I am just trying to learn to read the Clebsch-Gordan coefficients from the tables - but I am having hard time understanding them...
Here is the table http://pdg.lbl.gov/2002/clebrpp.pdf
Now using this table above, we wrote $$|\frac 3 2 , \frac 1 2 >=\sqrt{\frac 1 3}|\uparrow >|1>+\sqrt{\frac 2 3}|\downarrow >|0>$$ and $$|\frac 1 2 , \frac 1 2 >=\sqrt{\frac 2 3}|\uparrow >|1>-\sqrt{\frac 1 3}|\downarrow >|0>$$ Is there anybody that has 5 minutes of free time and could give me an idiot proof explanation? How do these tables work?
I'm guessing a bit, because you didn't give your notation. You seem to be adding angular momenta 1/2 and 1, so I guess that you are using the notation
| J, M \rangle = \sum_{m_{1}, m_{2}} c_{m_{1}, m_{2}} |m_{1} \rangle |m_{2} \rangle
with ##j_1 = 1/2##, ##j_2 = 1##.
The CG coefficients as expressed in the table as ##\langle j_1, j_2, m_1, m_2, | j_1, j_2, J, M \rangle##, which in your case means that the coefficients ##c_{m_{1}, m_{2}}## are
c_{m_{1}, m_{2}} =\langle 1/2, 1, m_1, m_2 | 1/2, 1, J, M \rangle
For example, let's find the coefficient in front of ##|\uparrow \rangle |1\rangle## that appears in the equation for ##|3/2 , 1/2 \rangle##. It will be
c_{1/2, 1} = \langle 1/2, 1, 1/2, 1, | 1/2, 1, 3/2, 1/2 \rangle
As you are adding ##j_1 = 1/2## with ##j_2 = 1##, you look at the values for ##1 \times 1/2## (the order of ##j_1## and ##j_2## is not important) and look for ##J = 3/2, M = +1/2## in an upper-right box, then for ##m_1=+1, m_2=+1/2## in the corresponding left box, and you don't find it! That's because the coefficient is 0! The triangle rule ##M = m_1 + m_2## is not followed, therefore the coefficient is zero, so you have made a mistake in your expansion for ##|3/2 , 1/2 \rangle##.
Now, can you try again?
Likes skrat
No, I can't. :D
The example I wrote is the example my professor wrote. Let me give you a bit background information about the problem we were solving with my professor.
We had a Hamiltonian ##H=\frac{p^2}{2m}+\lambda \delta(x)\vec{S_1}\cdot \vec{S_2}##. Than we said that ##S_1=1/2## and ##S_2=1##. Meaning that basis vectors for particle with ##S_1## are ##\left \{ |\uparrow>,|\downarrow> \right \}## while for particle with ##S_2## the basis vectors are ##\left \{ |1>,|0>,|-1> \right \}##.
We continued by saying that total spin ##S## can be ##\frac 3 2## or ##\frac 1 2 ##. (I am still trying to figure it out where these two numbers came from, but it is not important for the CG coefficients).
This leaves us with two possible groups of basis vectors. First one, we called it product basis, is ##\left \{ |\uparrow >|1>,|\uparrow >|0>,|\uparrow >|-1>,|\downarrow >|1>,|\downarrow >|0>,|\downarrow >|-1> \right \}## and the second one expressed with the total spin ##S## is ##\left \{ |3/2,3/2>, |3/2,1/2>, |3/2,-1/2>,|3/2,-3/2>, |1/2,1/2>, |1/2,-1/2> \right \}##
Now the whole idea is that using CG coefficients we can transform from one basis to antoher. And we wrote that ##|\frac 3 2 , \frac 1 2 >=\sqrt{\frac 1 3}|\uparrow >|1>+\sqrt{\frac 2 3}|\downarrow >|0>##.
BTW. Of course my professor explained this to us, but obviously I wasn't paying any attention - now this is the result.
EDIT: Oh, ok. I can see I made I mistake. We wrote ##|\frac 3 2 , \frac 1 2 >=\sqrt{\frac 1 3}|\downarrow >|1>+\sqrt{\frac 2 3}|\uparrow >|0>## and NOT ##|\frac 3 2 , \frac 1 2 >=\sqrt{\frac 1 3}|\uparrow >|1>+\sqrt{\frac 2 3}|\downarrow >|0>##
Oh, ok, I get it now. Thank you very much my friend. :)
skrat said:
We continued by saying that total spin SS can be 32\frac 3 2 or 12\frac 1 2 . (I am still trying to figure it out where these two numbers came from, but it is not important for the CG coefficients).
I think this comes from ##|S_1-S_2|\leq S \leq S_1+S_2##.
Correct!
hmmm... One stupid question... (still the same example ##|3/2,1/2>##)
You said, that I should look for ##J=3/2## and ##M=1/2## in the upper right box. But there are two of them. Following the wrong one gives me ##|3/2,1/2>=\sqrt{\frac{2}{3}}|\downarrow>|0>+\sqrt{\frac{1}{3}}|\uparrow>|-1>##.
Am.. I think the dilemma is obvious. Why is the first box ok and second one not?
The second box is gives you ##|3/2,1/2\rangle## and the third ##|3/2,-1/2\rangle##. So the correct equation is
|3/2,-1/2\rangle \sqrt{\frac{2}{3}}|\downarrow\rangle|0\rangle+\sqrt{\frac{1}{3}}|\uparrow\rangle|-1\rangle
Aaaa, so those J and M are written vertically and not horizontally!
Oh god... I can even see it written now in the top right corner http://pdg.lbl.gov/2002/clebrpp.pdf ..
Thank you!
  • · Replies 47 ·
