Real Analysis - Prove f is discontinuous
The function f defined as f(x) = 1 for rational x and f(x) = 0 for irrational x is proven to be discontinuous at every point in R. The proof involves constructing a sequence (x_n) that converges to a point x_0, alternating between rational and irrational values. This sequence demonstrates that the limit of f(x_n) does not converge, as it oscillates between 0 and 1. The approach utilizes the definition of continuity and properties of rational and irrational numbers.
  • Understanding of the definition of continuity in real analysis.
  • Familiarity with sequences and their convergence properties.
  • Knowledge of rational and irrational numbers.
  • Basic skills in constructing mathematical proofs.
  • Study the properties of discontinuous functions in real analysis.
  • Learn about sequences and series, focusing on convergence criteria.
  • Explore the implications of the density of rational and irrational numbers in R.
  • Investigate other examples of discontinuous functions and their proofs.
Students of real analysis, mathematicians interested in continuity and discontinuity, and educators teaching concepts of sequences and limits.
steelphantom
Let f(x) = 1 for rational numbers x and f(x) = 0 for irrational numbers. Show that f is discontinuous at every x in R.
Definition of continuity.
I want to find a sequence (x_n) that converges to x_0 but that x_n is rational for even n, and irrational for odd n. This will show that (f(x_n)) cannot converge, since it will alternate between 0 and 1, and thus f is discontinuous. My problem is that I can't think of a sequence that does this!
Thanks for any help. :smile:
Step 1: Find a rational sequence that converges to x.
Step 2: Find an alternating rational/irrational sequence that converges to 0.
(Hint: I suggest something of the form 0,y_1,0,y_3....)
Step 3: Add the two together.
How about (x_n) = x, and (y_n) = 0, 1/pi, 0, 1/pi^2, ... ? This should work, right? Thanks.
forget seqences
let U be an open set containing x
show f(U)={0,1}
If you must procede on the original path...
consider a standard rational sequence like
x_n=(n^-1)(floor(x*n)+(1/2)(1+(-1)^n))
altered like
x_n=(n^-1)(floor(x*n)+(1/sqrt(2))(1+(-1)^n))
If you know pi is irrational
maybe it is 4...
