Real analysis question: show that x^4 - x - 1 = 0 has two real roots
The problem involves the function f(x) = x^4 - x - 1, with the goal of demonstrating that it has two real roots. The discussion centers around the behavior of the function and the application of the intermediate value theorem.
  • Participants discuss the behavior of the function as x approaches positive and negative infinity, and evaluate f at specific points (f(0), f(1), f(-1)). There are inquiries about the existence of minima and maxima, and the use of the intermediate value theorem is considered.
Some participants have provided insights into the limits of the function and its values at specific points, suggesting that the function is continuous and must cross the x-axis. There is ongoing exploration of the function's extrema and the implications for the number of real roots.
Participants note that the problem does not require finding the roots explicitly, but rather demonstrating their existence. There is also mention of constraints regarding the use of the intermediate value theorem and the need to analyze the function's behavior comprehensively.
frenchkiki
Let f(x)=x^4 - x - 1. Show that f(x)=0 has two real roots.
None
x(x^3 - 1 - 1/x) = 0 which gives x=0 and x^3 - 1 - 1/x=0, x^2 - 1/x - 1/x^2=0, but WolframAlpha says x~~0.724492 and x~~-1.22074. I kept dividing by x it but couldn't come up with a sound result.
I don't think the point of this problem is to find the roots, but just to show they exist. Are you allowed to use the intermediate value theorem?
Find out the behaviour of the function as x goes either to infinity and to minus infinity. It is also useful to calculate f(0), f(1), f(-1), so as you get a picture of the function. Does it have minima and maxima? how many?
ehild
Yes I am allowed to use the intermediate value theorem.
as tends to inf: lim f(x) = inf
as tends to -inf: lim f(x) = -inf
f(0)=-1
f(1)=-1
f(-1)=1
I'm not sure on how to find the extremum though
No, this isn't true. As x approaches -∞, f(x) approaches +∞.
frenchkiki said:
f(0)=-1
f(1)=-1
f(-1)=1
The problem is not asking for this. Focus on what the problem is asking you to show. It might be helpful to sketch a rough graph of this function based on the two limits and the three function values above. Keep in mind the suggestion from gb7nash.
prove that: if f(x) = x4 - x - 1,
a) f tends to ∞ as x tends to -∞ or ∞.
b) f'(x) has at least one root
c) f has a global minimum
d) this minimum is < 0.
why does this tell you f has at least 2 real roots?
then show f has at most 2 roots (hint: look at part (b) again).
f(0)=-1
f(1)=-1
f(-1)=1
You see that the function is positive at x=-1, then negative at x=0. As it is continuous, it must be zero somewhere between -1 and 0. It is -1 again at x=-1, so there is a turning point, a minimum between x=0 and x=1. And the function is positive for large x values. Is it zero again somewhere between x=1 and infinity?
ehild
OK I figured this one out thanks to you guys:
from the I.V. theorem, there exists c=0 belonging to [a, b] with a=1 and b=-1 in the first case, second case with a=1 and b=2. therefore f(a)=-1<c=0<f(b)=1 and f(a)=-1<c=0<f(2)=13 so we have two real values for x.
Thanks y'all for your help!
  • · Replies 17 ·
