Rear Wheel Torque Equation Confusion
  • Thread starter Thread starter willeng
    Torque Wheel
4 replies · 4K views · last reply
willeng
I found some differing equations on the internet than what I thought on how to arrive at the rear wheel torque value for Motorcycles, so I thought I had better ask here to make sure.
One site said Rear Wheel Torque = Chain Tension X Tooth Count Ratio (front & rear sprockets)
I was under the impression that the formula was:
Rear Wheel Torque = Chain Tension X (Rear Sprocket Pitch Radius/Front Sprocket Pitch Radius)
At first I thought both would work out the same but after measuring some things & doing the numbers there is quite a difference in the final outcome.
Not sure now what to think?
Any help would be appreciated!
The answer is easy, since the pitch diameter and tooth count can both be used to find the reduction ratio:
Rear Sprocket Pitch Radius / Front Sprocket Pitch Radius
Rear Procket Tooth Count / Front Sprocket Tooth Count
Tooth Count Ratio
Pitch Radius Ratio
Reduction Ratio
