Recurrence Relations - Determining a solution of the recurrence relation
5 replies · 2K views
bigpunz04
Hello -
I am having a tough time understanding the problems in the attached picture (Problem 13). My issue is understanding how I plug in the proposed solutions, specifically those that include n. I am able to solve A and B but unable to solve the rest.
For instance, how do I plug in C or D into the original question? What do I do with the original sub values (n-1) and (n-2) ?
Here is the problem:
"Is the sequence {an} a solution of the recurrence relation
an = 8an-1 - 16an-2 if:"
a) an = 0?
b) an = 1?
c) an = 2n?
d) an = 4n?
e) an = n4n?
My approach to question c
8(2n-1) -16(2n-2)
which I believe gives me...
= 16n-1 - 32n-2
But that answer is obviously wrong. So I'm thinking that I am not plugging the solutions that include n properly. Ugghh so frustrated.
an = 8an-1 - 16an-2
(c)
8(2n-1) -16(2n-2)
note that $2^a(2^b) = 2^{a+b}$ ...
$2^3(2^{n-1}) - 2^4(2^{n-2})$
$2^{n+2} - 2^{n+2} = 0$
use the same property of exponents for (d)
skeeter said:
(c)
Thank you! That definitely gives me an idea and I will now brush up on my laws of exponents. Haven't used it in a while.
Looking at the answers in the back of the book, #c is not a solution for {an} since it is not equal to 2n. It also mentions that #d is a solution since 4n satisfies the equation. However, when I work the equation the same manner as you did, I end of with 0. It should end up with 4n in order to satisfy the equation.
Here is how I worked the problem. You'll notice that I am stuck again.
=8(4n-1) - 16(4n-2)
=23(4n-1) - 24(4n-2)
=23(22+n-1) - 24(22+n-2)
=0
8(4n-1) - 16(4n-2)​
$2^3[(2^2)^{n-1}] - 2^4[(2^2)^{n-2}]$
$2^3[2^{2n-2}] - 2^4[2^{2n-4}]$
$2^{2n+1} - 2^{2n}$
$2^{2n}(2 - 1) = 2^{2n}$
recommend you review properties of exponents
$2^{2n+1} - 2^{2n}$
I think you are right about reviewing exponential properties. Thank you so much.
Last question...
What happened to the +1 where you wrote 22n+1−22n ?
Thanks again, my friend. I now know exactly where I'm lacking and what I need to review.
$2^{2n+1} - 2^{2n}$
$2^{2n} \cdot 2^1 - 2^{2n}$
the two terms above have the common factor $2^{2n}$ ...
$\color{red}{2^{2n}}$ $\cdot 2 - $ $\color{red}{2^{2n}}$
... factor it out from the two terms
$\color{red}{2^{2n}}$ $(2 - 1)$
$2^{2n} (1) = 2^{2n} = 4^n$
