High School What is the relative speed of two groups of quasars with different redshifts?
The discussion focuses on calculating the relative speed of two groups of quasars with different redshifts, specifically redshift 10 and redshift 6. The redshift 10 group is considered "at rest," while the redshift 6 group is moving towards us. To determine the speed of the second group, it is suggested to calculate the redshift from motion while assuming both groups are at the same distance. The complexity arises from the non-linear nature of space, which means a unique result cannot be obtained, but a minimal velocity can be calculated using the Doppler shift formula. The conversation emphasizes the relationship between redshift, motion, and the implications of cosmological redshift as time dilation.
CosmologyHobbyist
TL;DR
speed calculation between two groups at different redshifts : redshift 10 & redshift 6.
If many quasars are at redshift 10, and another group is at redshift 6, what is the speed of the second group relative to the first? The redshift 10 group can be considered "at rest", so the redshift 6 group is heading in our direction at what rate? For this scenario, let us assume all the quasars are at same distance (as suggested by zero time dilation difference). Answer in percent of lightspeed please, but kilometers per second is ok, I can handle that conversion.
Astronomy news on Phys.org
Cosmological redshift is effectively time dilation. You are asking for two mutually exclusive conditions at the same time. But if you want to put them at the same distance: Calculate the redshift from motion at this place (the relative frequencies stay the same), then plug that into the Doppler shift formula. You won't get a unique result because space is not one-dimensional, but you can get a minimal velocity.
Thanks for your time, mfb.
UC Berkely, December 16, 2025 https://news.berkeley.edu/2025/12/16/whats-powering-these-mysterious-bright-blue-cosmic-flashes-astronomers-find-a-clue/ AT 2024wpp, a luminous fast blue optical transient, or LFBOT, is the bright blue spot at the upper right edge of its host galaxy, which is 1.1 billion light-years from Earth in (or near) a galaxy far, far away. Such objects are very bright (obiously) and very energetic. The article indicates that AT 2024wpp had a peak luminosity of 2-4 x...
  • · Replies 80 ·
26K
  • · Replies 28 ·
  • · Replies 67 ·
31K
