Region between two curves, trig twist?
  • Topic:
  • Thread starter Thread starter stripedcat
    Curves Trig
4 replies · 4K views · last reply
stripedcat
y = tan 3x, y = 2 sin 3x, −π/9 ≤ x ≤ π/9
It's looking for the area in blue there. Now obviously the -pi/9 to 0 is one region, then 0 to pi/9 is the other, but presumably you could find the area of one then double it (which is what I tried to do) but it wasn't right.
The incorrect answer I had was (2/3)*(ln(2)-1).
Could somebody tell me what I'm doing wrong?
  • Graph of two curves on x-y axes, x from -0.4 to 0.4 and y from -3 to 3, with the shaded region between them shaded light blue, crossing at the origin and near x = ±0.35.
Plugging that integral into Wolfram Alpha it looks like you are very close, but have a sign issue in the parentheses. The integral of the left/bottom region is 1/3(1-ln(2)). Doubling this is close to your answer, but with a sign change.
stripedcat said:
https://www.physicsforums.com/attachments/2694
The sign of the integral value to the left of 0 will be negative, and the sign of the integral value to the right of 0 will be positive. So if you do the entire integral at once, the two so-called "signed areas" will cancel out and leave you a value of 0 for the integral.
If you actually want the area, then you need to split it up into two integrals and then add the MAGNITUDES of the values you have found.
Yeah, it becomes negative, but a negative area?
This is what I was attempting to do, it didn't work. I don't know what I did wrong.
