How to Determine Whether to Accept or Reject a Hypothesis?
  • Thread starter Thread starter physicslady123
    hypothesis testing
This discussion focuses on determining whether to accept or reject a null hypothesis in statistical analysis. The sample size is 50, with 23 successes, and a significance level of 10%. The null hypothesis states that p = 0.4, while the accepted hypothesis posits that p > 0.4. Key calculations include the mean (μ = 20) and standard deviation (σ = 3.46), with confusion arising around the use of values 22.5 and 23.5 in probability calculations.
  • Understanding of null and alternative hypotheses
  • Familiarity with binomial distribution
  • Knowledge of calculating mean and standard deviation
  • Proficiency in using statistical significance levels
  • Learn about hypothesis testing in statistics
  • Study the Central Limit Theorem and its implications
  • Explore the use of t-distribution in hypothesis testing
  • Investigate the role of continuity correction in statistical analysis
Students in statistics, data analysts, and researchers involved in hypothesis testing and statistical inference will benefit from this discussion.
physicslady123
New poster has been reminded to post schoolwork problems in the Homework Help forums
Summary:: Confused on correction for contunuity
I'm confused about one step for questions like this where you have to determine to accept or reject the null hypothesis.
Sample size: 50
Number of successes: 23
Significance level: 10%
Null hypothesis: p = 0.4
Accepted hypothesis: p > 0.4
Solution:
μ = np
= (50)(0.4)
= 20
σ = √npq
= √(20)(0.6)
= 3.46
This is the part I'm confused on: To determine if I should accept/reject the hypothesis, would I do 1) or 2) or 3)
1) P ( x̅ >23)
= P ( x̅ > 23.5)
= 1-P(x̅<23.5)
and then solve
2) P ( x̅ >23)
= 1 - ( x̅ < 22.5)
and then solve
3) P ( x̅ < 23)
=P ( x̅ < 22.5)
and then solve
Why do you have to introduce 22.5 and 23.5 at all? Can't you just look at ##P(\bar{x} \geq 23)##?
What is your plan with the ##\sigma## you computed? Typically that means you are going to pretend that the values you are drawing are from some t distribution or something, and the fact that it's integer valued no longer is as much of an issue, since in the approximation the integers are not special values.
I would guess that in the question the samples are drawn from a binomial distribution and so the fact that it is integer valued is important. This question belongs in the homework section, I'll get it moved.
