Angle Decrease Rate for Kite String Related-Rates Problem
  • Thread starter Thread starter OmniNewton
OmniNewton
A kite 100ft above the ground moves horizontally at a speed of 8 ft/s. At what rate is the angle between the string and the horizontal decreasing when 200 ft of string has been let out? Answer: 0.02 rad/s
costheta = x/200
taking the derivative and rearranging
theta prime= x'/-200sintheta
substituting x' = 8 and theta = pi/6
theta prime = -0.08 rad/s
costheta = x/200
No, this is incorrect. The height of the kite is constant, but the length of the string is not constant.
I used ##\cot \theta = \frac x {100}## for my relationship between x and ##\theta##, and differentiated with respect to t to get the relationship between the rates.
My work agrees with the answer you posted, except that the answer should be negative -- the angle is decreasing, which means that ##\frac{d\theta}{dt}## is negative.
Alright makes sense thank you! I solved it
