Related to Constant acceleration
The problem involves a child driving a go-cart with an initial speed of 4 m/s and a constant acceleration of 0.4 m/s². The question focuses on determining the time taken to travel from a point 4 m from the start to a point 40 m from the start, specifically the distance of 36 m.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss different methods for calculating the time, including using kinematic equations. Some question the initial velocity to be used in the calculations, while others suggest using a quadratic equation approach.
There are multiple approaches being explored, with participants providing different equations and methods. Some guidance has been offered regarding the use of specific formulas, but no consensus has been reached on the correct approach or final answer.
Participants are working under the constraints of a homework assignment, which may limit the information available or the methods they feel comfortable using. There is also a noted confusion regarding the initial velocity and its implications for the calculations.
HelpMeHelpYou
Suppose a child driving a go-cart is traveling 4m/s when she crosses a line 4m from her starting point. She continues with a steady acceleration of 0.4m/s^2 , until she crosses a mark 40m from the starting point. How long does it take for her to go from the 4m mark to the 40m mark?
what i did is this :
a = 0.4m/s^2
Vi = 4m/s
d = 40m - 4m = 36m
i used this formula :
Vf = Vi + a*t
0 = 4m/s + (0.4m/s^2)t
-0.4m/s^2 = 4m/s
t = -10s
and this :
d = Vi+Vt/2 * t
36m = (4m/s + 0)/2 * t
36m = 2m/s t
divide both side by 2m/s
t = 18s
but the true answer is 6.7s
anyone correct this ?
the direct way to solve it, without having to calculate the final velocity, is to use
d = V1 t + a t2 /2
put in the values d= 36, a=0.4 and solve the quadratic equation in t using the normal formula. Its obviously the positive value of t you take.
Hope this helps
Regards
Sam
how about the velocity ? Vi = 0 or 4m/s ?
4 m/s
36=4t+0.2t^2
just a confirmation ..
correct this if I'm wrong ..
d = 36
a = 0.4
i used :
d = V1 t + a t2 /2
subst:
36 = 0 t + 0.4 t2 /2
divide both sides by 0.4
90 = t2 /2
divide both sides by 1/2
45 = t2
square root both sides to remain t :
t = 3√5 or 6.7
is it correct usage of algebra ?
try 36 = 4t+0.2t2
0.2 t2 +4t -36 =0
t = (-4 + √(16+4*0.2*36))/(2*0.2)
t≈6.7 seconds
whow ! again .. i should study back again .. so thanks Sam ..
gratitude !
  • · Replies 17 ·
