Granger
- Messages
- 165
- Reaction score
- 7
Consider a coaxial cable which consists of an inner cylindrical conductor of radius R1, and a shell cylindrical conductor of radii R2 and R3. The 2 conductors are separated with a dielectric material of permittivity ε. Consider the length of the cable, ℓ, much larger than R3. The cable is connected to a voltage source V. Determine the polarization charge distribution per unit of length.
3. The Attempt at a Solution [/B]
So I have no problem calculating the surface polarization charge distribution.
Having:
$$D=\frac{\lambda}{2 \pi r}$$
$$E=\frac{\lambda}{2 \pi \epsilon r}$$
$$P=\frac{\lambda (\epsilon - \epsilon_0)}{2 \pi r \epsilon}$$
$$V=\frac{\lambda}{2 \pi \epsilon} \times \log{\frac{R_2}{R_1}}$$
Than we should have in r=R1:
$$\sigma= -\frac{V (\epsilon - \epsilon_0)}{R_1 \log{\frac{R_2}{R_1}} }$$
Now they as for the density by unit of length and the answer should be:
$$\lambda= -\frac{2 \pi V (\epsilon - \epsilon_0)}{\log{\frac{R_2}{R_1}} }$$
According to the answer, the relation between lambda and sigma should be:
$$\lambda = 2 \pi R_1 \sigma$$
However I don't understand how it can be?
So my question is exactly how to get to that relation between lambda and sigma (if that relation is correct, of course).
Thanks!
