Relationship between a given volume for a cylinder and the minimum surface area.
The discussion revolves around establishing a mathematical model that describes the relationship between a given volume of a cylindrical container and the minimum surface area required for its construction. The subject area includes geometry and calculus, particularly focusing on the properties of cylinders.
  • Participants discuss the expressions for volume and surface area of a cylinder, questioning how to derive a relationship between them. Some suggest writing equations in terms of radius and height, while others express confusion about the uniqueness of surface area for a given volume.
There is an ongoing exploration of the mathematical relationships involved, with some participants attempting to clarify the definitions and implications of the equations. Guidance has been offered regarding differentiation to find minimum surface area, but there remains a lack of consensus on the interpretation of the problem.
Participants are navigating the constraints of homework rules, emphasizing the need for a general equation applicable to any volume while defining minimum surface area. There is also a mention of a misplacement of the thread topic, indicating a potential misunderstanding of the problem's context.
stevie :)
I currently have a question that i am struggling with it is:
Propose a mathematical model in the form of an equation desribing, in general terms, the relationship between a given volume for a cylindrical container and the minimum surface area of material required to make it..
i am struggling with understanding this and actually defining an equation. please some assistance with this topic?
You could write down the expressions for the volume V and the area A (both dependent on r and h), and work out V / A.
Edit: so you can get an equation of the form V = k A, where k is some coefficient dependent on r and h, and thus you have a relation V = V(A) which expresses the volume in terms of the area.
ok just with that 1st comment i don't really understand that... could you show me how to work that out using r and h
If I got your question right, it doesn't really make any sense. Let's say you have a given volume of a cylinder, V. For this volume the surface (i.e. the material surface of the cylinder) is unique. What I meant (if this was your question) was to find how many surface of material you need for a certain volume, i.e. a relation between the volume and material needed to build it.
That's not true. Both Volume and surface area of a cylinder depend on the height and radius: [itex]V= \pi r^2 h[/itex] and [itex]S= 2\pi rh+ 2\pi r^2[/itex]. There will be different values of r and h which give the same volume but different surface areas.
With fixed V, [itex]h= V/(\pi r^2)[/itex] so the surface area is [itex]S= (2\pi r)(V/(\pi r^2))+ 2\pi r^2= 2V/r+ 2\pi r^2[/itex]. Differentiate that with respect to r and set the derivative equal to 0 to find the minimum surface are for a given volume.
(Since this whole thread has nothing to do with "differential equations", I am moving it to "Calculus".)
ok sorry bout putting in the wrong place...
i think what the question is asking is for any volume, like a general relationship that works for any volume and will give the minimum surface area for that volume...
but by differentiating A = 2V/r+ 2\pi r^2 with respect to r doesn't that simply give you a value for a minimum radius of the container after you set it = 0?
volume and surface area relationship
v=pi*r^2*h
a=2*pi*r*h + 2*pi*r^2
we are asked to find a general equation that works for any given volume and will define the minimum surface area for that volume...
no attempt as yet
(two threads merged)
Stevie -- you need to try harder. We do not do your homework or schoolwork for you here. We are here to help as you work through the problem.
that's what I am asking for... i don't understand how to find the relationship between any given volume and the minimum surface area so I'm asking for some assistance to get it started
(Halls, thanks - my apologies to Stevie for eventual misguide)
  • · Replies 33 ·
15K
