Relationship between inequalities in proofs
The discussion clarifies the relationship between inequalities in mathematical proofs, specifically between the symbols "≤" and "<". It establishes that while "abs(b) ≤ a" implies "abs(b) < a" under certain conditions, one cannot universally replace "≤" with "<" without potentially altering the truth of the statement. The example provided illustrates that continuous functions satisfying "f(x) < 1" for all x in the interval [0, 1) lead to the conclusion "f(1) ≤ 1", which cannot be changed to "f(1) < 1" without invalidating the proof.
  • Understanding of mathematical inequalities
  • Familiarity with the concepts of continuity in functions
  • Knowledge of absolute values and their properties
  • Basic proof techniques in mathematics
  • Study the properties of inequalities in mathematical proofs
  • Learn about the implications of continuity in functions
  • Explore the differences between "≤" and "<" in mathematical contexts
  • Investigate common pitfalls in mathematical reasoning involving inequalities
Mathematicians, students studying real analysis, educators teaching proof techniques, and anyone interested in the nuances of mathematical inequalities.
Seacow1988
Hi,
Could you clarify the relationship between proofs that use ≤ and those that use <?
For example, if it's already proven that "abs(b) ≤ a if and only if -a≤ b≤a" can we say this implies that "abs(b) < a if and only if -a< b<a"? It seems that since the first statement holds for all abs(b) "less than or equal to" a, its application could narrowed to the case where abs(b) was simply "less than" a.
Thanks!
Seacow1988 said:
Hi,
Thanks!
It happens to be so for that example. But you can't just change them willy-nilly.
For example consider this statement:
If a function f which is continuous on 0 ≤ x ≤ 1 satisfies the inequality f(x) < 1 for all x with 0 < x < 1, then f(1) ≤ 1.
You can't change the conclusion to f(1) < 1 without making the statement false.
Consider the fact that for any real number a in R, -|a| ≤ a ≤ |a| is true. It would be false it we replaced "≤" with "<". The symbol "≤" between two numbers x and y is logically equivalent to the statement "x < y OR x = y".
  • · Replies 20 ·
