Relative Error of Right Triangle Area
The discussion focuses on calculating the relative error of the area of a right triangle using the formula A=1/4H^2sin(2x), where H is the hypotenuse and x is one of the acute angles. The user initially calculated the area for H=4cm and x=30 degrees, yielding a relative error of approximately 0.2887. However, it was clarified that the angle x must be converted to radians for accurate differentiation, leading to a corrected relative error of approximately 0.005 after recalculating with dx in radians.
  • Understanding of right triangle area formulas
  • Knowledge of differentiation and differentials
  • Familiarity with trigonometric functions and their derivatives
  • Ability to convert angles between degrees and radians
  • Study the application of differentials in geometry
  • Learn about the implications of angle measurement in calculus
  • Explore the use of trigonometric identities in area calculations
  • Investigate error analysis techniques in mathematical computations
Students studying calculus, particularly those focusing on applications of differentials in geometry, as well as educators and tutors seeking to clarify concepts related to angle measurement and error estimation.
Jimbo57
Anyone mind checking my answer for me?
The area of a right triangle with hypotenuse H is
A=1/4H^2sin(2x)
x is one of the acute angles. Use differentials to estimate the relative errors of the area if H = 4cm exactly and x is measured to be 30degrees with an error of measurement of 15 minutes of arc.
A=1/4H^2sin(2x)
dA=1/2H^2cos(2x)dx
dA/A=2cot(60)(0.25)
A=1/4*16sin(60)=3.464cm^2
dA=8cos(60)(0.25)
=0.125cm^2
dA/A=0.125/3.464=0.2887=relative error
Now, did I have to convert to radians in step one? 30 to pi/6? Or is this right?
A=1/4H^2sin(2x)
A=1/4H^2sin(2x)
dA=1/2H^2cos(2x)dx
dA/A=2cot(60)(0.25)
dA=8cos(60)(0.25)
=0.125cm^2
The formula d(sin(2x))=2*cos(2x)*dx is correct only if x is measured in radians. You can call the 2x part either 60 degrees or pi/3 if you adjust your calculator for degrees or radians, but the dx part definitely needs to be in radians.
Thanks Dick. So the steps I took were correct just needed to convert to radians?
How does this look?
15/60 degrees = 0.00436rad=dx
A=1/4*16sin(pi/3)=3.464cm^2
dA=8cos(pi/3)(0.00436)
=0.01744cm^2
dA/A=0.01744/3.464≈0.005=relative error
How does this look?
=0.01744cm^2
That sounds much better.
12K
19K
