Did I Miss Something in Disputing a Popular Book's Solution on Relative Motion?
The discussion centers on the nuances of relative motion as presented in a popular physics book. The key takeaway is that when dealing with rotating frames, the derivatives of vectors are influenced by the angular velocity of the frame. Specifically, if frame ##\mathcal{B}## rotates at angular velocity ##\boldsymbol{\omega}## relative to frame ##\mathcal{A}##, the relationship between the derivatives of an arbitrary vector ##\mathbf{u}## in these frames is defined by the equation $$\left( \frac{\mathrm{d}\mathbf{u}}{\mathrm{d}t} \right)_{\mathcal{A}} = \left( \frac{\mathrm{d}\mathbf{u}}{\mathrm{d}t} \right)_{\mathcal{B}} + \boldsymbol{\omega} \times \mathbf{u}$$. This highlights the importance of understanding how vector derivatives are defined in different reference frames.
  • Understanding of vector calculus and derivatives
  • Familiarity with angular velocity concepts
  • Knowledge of rotating reference frames
  • Basic principles of classical mechanics
  • Study the relationship between angular velocity and vector derivatives in rotating frames
  • Explore the mathematical foundations of rotation matrices, specifically time-dependent rotation matrices
  • Read Douglas Gregory's classical mechanics text for deeper insights into relative motion
  • Investigate the implications of invariant vectors in different reference frames
Students and professionals in physics, particularly those focusing on classical mechanics, as well as educators looking to clarify concepts of relative motion and rotating frames.
guv
200 More challening physics problems question #2
Ann is sitting on the edge of a carousel that has a radius of 6 m and is
rotating steadily. Bob is standing still on the ground at a point that is 12 m from the
centre of the carousel. At a particular instant, Bob observes Ann moving directly
towards him with a speed of 1 m s−1. With what speed does Ann observe Bob to
be moving at that same moment?
The hint from the book: Be careful, the transformation principle due to Galileo Galilei applies
only to inertial reference frames. The idea that Ann simply observes Bob moving
towards her with a speed of 1 m s−1 is false.
Solution: some complex calculation involving using the center of the carousel. Bob's velocity relative to the center is decomposed into tangetial and radial components, the tangential components ##\sqrt{3}## m/s is used as solution.
$$v_{a/b} = - v_{b/a}$$
I do not agree, this is bullocks. We can simply set up position vector of ##\vec A(t)## and ##\vec B(t)## with respect to the fixed center of the carousel, their relative velocity is simply ##\frac{d (A-B)}{dt}## or ##\frac{d (B-A)}{dt}##
Since this is a pretty popular book, I am wondering if I overlooked any detail in disputing the book's solution.
The book is right! The answer is that in general, for frames that are permitted to rotate, the derivatives of vectors depend on the angular velocity of the frame! As a theorem, if frame ##\mathcal{B}## rotates at ##\boldsymbol{\omega}## relative to frame ##\mathcal{A}##, then the derivative of an arbitrary vector ##\mathbf{u}## with respect to these two frames are related by$$\left( \frac{\mathrm{d}\mathbf{u}}{\mathrm{d}t} \right)_{\mathcal{A}} = \left( \frac{\mathrm{d}\mathbf{u}}{\mathrm{d}t} \right)_{\mathcal{B}} + \boldsymbol{\omega} \times \mathbf{u}$$It is because of how we define the derivatives of vectors with respect to ##\mathcal{A}## and ##\mathcal{B}##. If ##\{\mathbf{e}_i \}## is the basis of ##\mathcal{A}##, for instance, and ##\{\tilde{\mathbf{e}}_i \}## a basis for ##\mathcal{B}## then you have ##\mathbf{u} = u_i \mathbf{e}_i = \tilde{u}_i \tilde{\mathbf{e}}_i##, and we define:$$\left( \frac{\mathrm{d}\mathbf{u}}{\mathrm{d}t} \right)_{\mathcal{A}} := \sum_i \frac{\mathrm{d}u_i}{\mathrm{d}t} \mathbf{e}_i$$i.e. treating the ##\mathcal{A}## basis as constant, whilst$$\left( \frac{\mathrm{d}\mathbf{u}}{\mathrm{d}t} \right)_{\mathcal{B}} := \sum_i \frac{\mathrm{d}\tilde{u}_i}{\mathrm{d}t} \tilde{\mathbf{e}}_i$$i.e. treating the ##\mathcal{B}## basis as constant. You can see how they are related by writing ##\tilde{\mathbf{e}_i} = R_{ij}(t) \mathbf{e}_j## where ##R_{ij}(t)## is a time-dependent rotation matrix.
So even though the relative position vector ##\mathbf{x}## is indeed invariant (as all vectors are), its time-derivatives with respect to both frames are different. For more info consult a classical mechanics text e.g. Douglas Gregory.
Very good, that was the detail I overlooked. Thanks.
Likes berkeman and etotheipi
  • · Replies 0 ·
  • · Replies 17 ·
