Relative Velocity and Projectile Motion
The discussion focuses on calculating the angle at which a helicopter should release documents to hit a moving car below. The helicopter travels at 215 km/h (59.7 m/s) and the car at 155 km/h (43.1 m/s), with a vertical drop of 78.0 m. The correct angle of release is determined to be 49.6 degrees, after calculating the time of fall and horizontal distance traveled. The initial confusion regarding relative velocity is clarified through the use of kinematic equations for constant acceleration in two dimensions.
  • Kinematic Equations for Constant Acceleration
  • Understanding of Projectile Motion
  • Basic Trigonometry (Tangent Function)
  • Relative Velocity Concepts
  • Study Kinematic Equations for Projectile Motion in-depth
  • Learn about Relative Velocity in Two Dimensions
  • Explore the application of Trigonometric Functions in Physics Problems
  • Practice similar problems involving projectile motion and relative velocity
Students studying physics, particularly those focusing on mechanics and projectile motion, as well as educators looking for practical examples to illustrate these concepts.
Kandycat
A low-flying helicopter flying a constant 215 km/h horizontally wants to drop secret documents to his contact's open car which is traveling 155 km/h on a level highway 78.0 m below. At what angle (to the horizontal) should the car be in his sights when the packet is released?
Kinematic Equations for Constant Acceleration in Two Dimensions
X-component (horizontal):
vx = vx0 + axt
x = x0 + vx0t + .5axt2
vx2 = vx02 + 2ax(x-x0)
Y-Component (vertical):
vy = vy0 + ayt
y = y0 + vy0t + .5ayt2
vy2 = vy02 + 2ay(y-y0)
Knowns:
Vhelicopter = 59.7 m/s
Vcar = 43.1 m/s
y = -78 m
y0 = 0
x0 = 0
g = -9.8 m/s2
vy2 = ?
vy2 = 0 + 2 (-9.8 m/s2)(-78 m)
vy = 39.1 m/s
vx = Vhelicopter + Vcar = 59.7 m/s + 43.1 m/s = 102.8 m/s ? <-- I'm not sure I did this right. Probably didn't.
tan Θ = vy/vx = 39.1/102.8
Θ = 20 degrees
But the back of the book says that the answer is 49.6 degrees. I'm probably wrong and somewhere in my work I screwed up somewhere. My calculator is in degree mode.
Ok try finding the x distance the parcel will travel and take the inverse tan of the ratio of the two sides (i.e. x - distance and y - distance).
All right. I'm not sure if this is correct or not, but I found time.
-78 m = 0 + 0 + .5 (9.8 m/s2)t2
t = 3.99 s
Then after I found time. I took your advice.
x = 0 + (59.7 m/s - 43.1 m/s)(3.99 s) + 0
x = 66.2 m
tan Θ = y/x = 78 m/66.2 m
Θ = 49.6 degrees
I'm still a bit confused about relative velocity though. Can someone explain how relative velocity works?
Thank you so much for your help!
  • · Replies 30 ·
