Relative Velocity of Two Objects Moving at Different Speeds
The discussion revolves around calculating the relative velocity of a laser beam fired from an intergalactic cruiser towards a hostile spacecraft, with both vehicles moving at constant speeds. The Speed-of-Light Postulate states that the speed of light remains constant at c in any inertial reference frame, leading to the conclusion that the laser beam's velocity relative to the spacecraft is c. However, the second question addresses how the speed of light is perceived by an observer in a different frame, which requires understanding the relative motion between the cruiser and the observer. The analogy of throwing a ball highlights that the perceived speed of an object is not simply additive when considering relative motion, emphasizing the importance of the observer's frame of reference. The key takeaway is that careful consideration of who is observing and measuring is crucial in relativity problems.
Tranceform
An intergalactic cruiser is approaching a hostile spacecraft . Both vehicles move at a constant velocity. The velocity of the cruiser relative to the spacecraft is vCS=+0.7c, the direction to the right being the positive direction. The cruiser fires a beam of laser light at the hostile renegades. The velocity of the laser beam relative to the cruiser is vLC=+c.
a) What is the velocity vLS of the laser beam relative to the renegades’ spacecraft ?
b) What is the velocity v at which the renegades see the laser beam move away from the cruiser?
The Speed-of-Light Postulate: The speed of light in a vacuum, measured in any inertial reference frame, always has the same value of c, no matter how fast the source of light and the observer are moving relative to each other.
In both cases, it is asked how the speed of light is percieved. Question a) makes sense, as it's asking for the speed of light relative to an inertial reference frame. According to The Speed-of-Light Postulate of special relativity, light traveling in vacuum perceived in an inertial reference frame always has the value of c so the answer is vLS=+c. What I'm wondering about is question b). In order to answer this question I need to understand the following:
How is question b) different from question a)? In question b) it is also being asked how the speed of light is perceived viewed from an inertial reference frame, so according to the abovementioned postulate it should also be +c. But that is not the correct answer. Why is it not that?
Think of it like this, if I am going at 2m/s wrt you, and I throw a ball at 5m/s towards you (also wrt you), how fast do you see the ball leaving my hand?
Is this analogy in reference to question a) or b)? I thought this analogy didn't apply for light? Suppose for example that you instead of throwing a ball shined a flashlight, the speed of light postulate says that I wouldn't see this light as c+2m/s even though you are moving but I would still see it as having speed c?
Refers to part (b). All the laws of physics have to work normally in an inertial reference frame, as long as all measurements are taken by the same inertial observer.
You need to read my analogy more carefully.
You would not see the ball leave my hand at 2+5=7m/s either.
You would still see the ball move wrt you at 5m/s.
I am moving wrt you at 2m/s.
The gap between me and the ball is increasing.
So how fast is the gap between me and the ball increasing?
That is how fast the ball leaves my hand, as measured by you.
Lets say I am using a flashlight, and I use it to fire a pulse of light at you.
So I am moving towards you at speed 2m/s
The light pulse is moving towards you at speed c.
The gap between me and the light pulse is increasing - how fast?
That is what part (b) is asking.
Thanks for clarifying!
No worries - it's very common. The key to relativity problems, all kinds, is to be very careful about who is doing the observing/measuring etc. What are the measurements being made with respect to? Sometimes the clue is only in one or two words.
Try this:
If Alice travels to the left, according to Oscar, at 0.9c, and Bob travels to the right, according to Oscar, at 0.9c, how fast is the distance between Alice and Bob increasing (according to Oscar)?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
