Relativistic electrodynamics: transformation of electric dipole moment
  • Thread starter Thread starter lys04
The discussion revolves around the transformation of the electric dipole moment and its relation to the magnetic dipole moment in the context of relativistic electrodynamics. The original poster presents a scenario involving a charge distribution with a static charge density and a net electric dipole, seeking to determine the magnetic dipole moment as observed in a different frame moving at a constant velocity.
  • Participants explore the transformation of the electric dipole moment into the magnetic dipole moment, discussing the implications of splitting components parallel and perpendicular to the velocity vector. Questions arise regarding the treatment of the volume element and the effects of length contraction on the components of the dipole moment.
Some participants express uncertainty about the correctness of the original poster's approach, particularly regarding the volume element's transformation and the treatment of components. There is a recognition that the perpendicular component contributes to the magnetic dipole moment, while the relevance of the parallel component is debated. Guidance is offered on how to handle the transformation of the volume element and its implications for the integral.
Participants note that the charge distribution's movement and the transformation of charge density may require further justification, particularly in relation to time-dependent versus time-independent representations. The discussion reflects a mix of established concepts and ongoing exploration of relativistic effects.
lys04
^^As title suggests
Lorentz transformation matrix, current 4-vector
A charge distribution stationary in its own frame S’ has a static charge density ##\rho ’##, a total charge of 0 and a net electric dipole ##\vec{p'}##. An observer in frame S sees the charge distribution moving with constant velocity ##\vec{v}=c \vec{\beta}## What is the magnetic dipole moment in S?
Split the electric dipole moment into components perpendicular and parallel ##\vec{\beta}##, i.e ##\vec{p'}_\parallel## and ##\vec{p'}_\perp##
Then the current density in frame S is given by ##\vec{j} = c \gamma \rho ' \vec{\beta}##
Now using the definition of magnetic dipole moment: ##\vec{m} = \frac{1}{2} \int_V \vec{x} \times \vec{j} dV##
Split $\vec{x}$ into components perpendicular and parallel to ##\vec{\beta}##, i.e ##\vec{x}_\parallel## and ##\vec{x}_\perp##
##\vec{m} = \frac{c \gamma}{2} \int_V ( \vec{x}_\parallel + \vec{x}_\perp) \times (\rho ' \vec{\beta}) dV##
##\vec{m} = \frac{c \gamma}{2} \int_V \rho ' ( \vec{x}_\parallel + \vec{x}_\perp) \times \vec{\beta} dV##
##\vec{m} = \frac{c \gamma}{2} \int_V \rho ' \vec{x}_\perp \times \vec{\beta} dV##
##\vec{m} = \frac{\gamma}{2} \int_V \rho ' \vec{x}_\perp \times \vec{v} dV##
##\vec{m} = \frac{\gamma}{2} \int_V \rho ' \vec{x}_\perp dV \times \vec{v} ##
##\implies \vec{m} = \frac{\gamma}{2} \vec{p'}_\perp \times \vec{v}##
Is this correct?
This doesn't look correct to me.
What about the volume element, how does that/ should that change? (I just did this in emag2 and we blew through this at the end, so.... I could be wrong.)
Yeah I thought about that, I’m not sure how to do it tho since the direction is not specified but instead in some arbitrary direction.
Arbitary should be fine, infact you don't even need to pick a basis for this.
So dV = dLdA, you can now choose dL so that it is parallel and dA so that its perpendicular. How would dL change under the transformation? Then go back to dV' and you're basically done.
So dV = dLdA, you can now choose dL so that it is parallel and dA so that it’s perpendicular. How would dL change under the transformation? Then go back to dV' and you're basically done.
Sorry for the late reply.
Hm so by length contraction for the component of dl parallel to the direction of v it gets contracted? dl’=dl/gamma?
Yeah, this is how I would I do it.
So then ##dV'=dA dl' = \frac{dA dl}{\gamma} = \frac{dV}{\gamma}##?
This is dV' when the component of dl is parallel to the direction of v. How do I deal with the component that's perpendicular? It doesn't change right? (But is the perpendicular component really needed anyways?)
So then if I plug that back into my integral I get the same answer but without the gamma factor? ##\frac{1}{2} \vec{p'}_\perp \times \vec{v}##?
Yes, the perpendicular component doesn't change. ##dV = \frac{dV'}{\gamma}##, so you plug that back in and you get ##\frac{1}{2}\vec{p'}_{\perp} \times \vec{v}##.. which obviously matches the non relativistic expression. (This isn't a great check here since what you wrote before also matches the non relativistic expression when ##\gamma \approx 1##.)
Yeah and also only the perpendicular component contribute to the magnetic dipole moment which kinda surprises me since the parallel component is the bit that's moving?
And also this annoys me but what do I do with the dl that's perpendicular to the direction of v? it seems like that's being ignored..
Note that ##\frac{1}{2} \vec{p'}_\perp \times \vec{v}=\frac{1}{2} \vec{p'}\times \vec{v}## .
Although the result seems OK (up to a possible power of ##c##), I think the replacement of the time-dependent ##\rho## by the time-independent ##\rho'/\gamma## can have a better justification (hint: ##\rho(t,\vec{x}## ) should be expressed as a function of the S coordinates.
The charge distribution is moving in S, so ##\vec{x}_\parallel## should be replaced here by ##(\vec{x}_\parallel+\vec{v}t)/\gamma## . Since both vanish after the ##\times## product, this omission doesn't affect the later results.
For the first bit, It's just the nature of what a magnetic dipole moment is and comes from the cross product. For the second but, it's not being ignored, it's actually the relevant part.
I wanted to give a better answer, so I've been reading up and found this article: MDM
This is for the transformation of a magnetic dipole moment, not electrical dipole, but I think it should be analogous.
I would say what you have is correct enough now for a homework problem, but I'm not sure its complete now. If that makes sense.
  • · Replies 32 ·
