Relativity: Test charge moving perpendicular to a current carrying wire exhibits a force
The discussion revolves around the behavior of a test charge moving perpendicular to a current-carrying wire, particularly how relativity influences the forces experienced by the charge. Participants explore the implications of magnetic and electric fields in different reference frames, and the conversation touches on both qualitative and quantitative aspects of the phenomenon.
  • One participant inquires about how relativity applies when a test charge moves perpendicular to a current-carrying wire, questioning if the force can be explained by charge distribution in the particle's frame.
  • Another participant suggests transforming the magnetic field and current density to analyze the situation.
  • A different viewpoint raises the possibility of using length contraction similarly to Einstein's derivation for a charge moving along the wire.
  • One participant mentions that the explanation involving different length contraction effects for electrons and protons is attributed to Purcell rather than Einstein, proposing to transform the 4-current density for further insight.
  • A detailed qualitative explanation is provided, describing the motion of positive and negative charge carriers in the wire and how their distribution affects the electric field experienced by the moving charge.
  • Another participant expresses appreciation for the explanation and discusses the concept of 'pancakification' of the electric field, questioning if this effect also occurs when the charge moves parallel to the wire.
  • A later reply asserts that the 'pancakification' can be described as a Lorentz contraction effect and that the classical case yields correct results without needing an additional effect.
Participants express differing views on the role of length contraction and the 'pancakification' effect, indicating that multiple competing perspectives remain without a clear consensus on the explanations provided.
Some participants reference specific texts, such as Purcell's book, to support their arguments, indicating that the discussion may depend on interpretations of these sources. The discussion also highlights the complexity of the interactions between electric and magnetic fields in different reference frames.
Glare
TL;DR
Test charge moving perpendicular to a current carrying wire exhibit a force. What is the relativistic explanation in the charge rest frame?
Given a test charge moving along a current carrying wire, I'm familiar with the relativity explanation of the magnetic field at the rest frame of the wire and the electric field In the moving particle frame (where the wire is electrically charged).
My question is how relativity kicks in in the case where the test charge is moving perpendicular to the wire?
Can the force on the particle be explained by some charge distribution over the wire at the particle frame?
Of course. Just transform the magnetic field and the current density and see what you get
Yes, but can we reach it only by using length contraction in similar way to how Einstein derived it for a charge moving along the wire?
As far as I'm aware the explanation with different length contraction effects for electrons and protons is a post hoc description by Purcell, not a derivation by Einstein. Unless you have some other reference in mind?
Given that, I'd transform the 4-current density and see what the result looks like. Then I'd try to find an "intuitive" explanation for that.
Here's an attempt at a qualitative explanation.
Suppose we have a very long, straight wire with current. Imagine the current is due to motion of both positive and negative charge carriers.
The positive charges are shown in red and move upward. The negative charges are blue and move downward at the same speed. The charge density is the same for the positive and negative charge. The net current is upward. The magnetic field in the region to the right of the wire points into the page. So, a positive point charge that moves away from the wire toward the right will experience a magnetic force upward:
If we go to the rest frame of the moving charge ##q##, the upward force on ##q## must be due to an electric field. We want to see how this happens. In the rest frame of ##q##, the wire moves toward the left. So, the positive charges in the wire move upward and to the left. The negative charges in the wire move downward and to left. This is shown in the figure below. In the small region of the wire marked ##A##, the red arrow indicates the velocity of the positive charge carriers, the blue arrow denotes the velocity of the negative carriers.
A uniformly moving point charge has a radial field that is stronger in directions perpendicular to the velocity direction. This relativistic effect is very small for non-relativistic speeds, but it's important here (I think).
The pattern of the field lines for the carriers in region ##A## are shown schematically below:
Finally, consider the diagram below which shows symmetrically placed regions ##A## and ##B## of the wire. The electric fields produced by the carriers in ##A## and ##B## at the location of the charge ##q## are shown.
The red arrow ##E_A## denotes the field at ##q## produced by a positive carrier in region ##A##. The blue arrow ##E_A## is the field produced by a negative carrier in region ##A##. The blue field ##E_A## is stronger than the red field ##E_A## because the direction from ##A## to ##q## is closer to being perpendicular to the direction of the velocity of the negative charge carrier in ##A## than to that of the positive charge carrier. Similarly, the red ##E_B## and blue ##E_B## are the fields at ##q## due to the positive and negative carriers in ##B##, respectively. Here, red ##E_B## is strong than blue ##E_B##.
When you add the four field vectors at ##q## you get a net electric field that is upward, parallel to the current.
[EDIT: This qualitative analysis can be found in Purcell's textbook: chapter 6 in the first edition and chapter 5 in the second and third editions.]
Amazing explanation.
Thank you very much!
Thank you very much 🙏
Isn't this 'pancakification' effect of the electric field should also take place in the 'classical' case where the particle moves parallel to the wire, (as In addition to the length contraction effect).
Isn't these two mechanism compete each other?
No. This 'pancakification' can be described as Lorentz contraction effect. The same applies to the line density of charge in the 'classical' case. In Purcell's book, the 'classical' case is calculated and gives a correct quantitative result without an "additional" effect.
  • · Replies 20 ·
  • · Replies 68 ·
  • · Replies 27 ·
  • · Replies 34 ·
  • · Replies 25 ·
  • · Replies 28 ·
