- 18
So do you also think the Lorentz transformation equation dt' = gamma*(dt - v*dx/c^2) has no practical use? Is there any practical way to verify that for two events that have a dx of 10 light-seconds in our frame and a dt of 8 seconds in our frame, the events would have a dt' of 0 in a frame moving at 0.8c relative to us?starthaus said:Which means that such a definition of synchronization has no practical use.
I don't know what "synchronization definition" you are using that's different from mine. My definition had nothing to do with a specific pair of events so I am not considering any particular value of dt, my definition is just that if two clocks show the same reading at every time-coordinate in a given frame, they are "synchronized" relative to that frame. Are you using a different definition?starthaus said:This is incorrect, the synchronization definition employing [tex]dt=0[/tex] does not imply any observation of the clocks.
"Did not get out of sync" in your frame, or in the rest frame of the clocks? If you accelerate both clocks at the same coordinate acceleration in your rest frame, then both clocks will remain synchronized in your frame, which means according to my definition of synchronization above, they will become out-of-sync in their new rest frame.starthaus said:All you need to know is that they had been accelerated slowly enough such that they did not get out of synch.
OK, suppose that while the rocket is accelerating up to relativistic speed, both clocks are right next to each other in the middle of the rocket. This means we can know theoretically that they remain "synchronized" in all frames (both our frame and other frames) according to my definition above, as long as they are together. Then once the rocket is coasting, there's a device which automatically pushes one clock slowly along a track towards the front of the rocket, and which automatically pushes the other slowly along a track towards the back (the device is designed to push both clocks at the same slow speed relative to the rocket). In that case, we can determine theoretically that the after reaching the front and back the two clocks should still be "synchronized" in the current rest frame of the rocket (according to my definition above), and that this means that two readings on the clocks which have a separation of vL/c^2 should occur simultaneously in our frame.starthaus said:For that extent, the clocks may be totally enclosed in arocket, unobservable, you will still be able to determine their desynchroonization in frame F' based only on two things : proper length L and coordinate speed v.
