Residue of a ratio of polynomials
The discussion focuses on finding the inverse Laplace transform of the function \(\frac{s^2-a^2}{(s^2+a^2)^2}\) using the residue definition. The poles of the function \(F(s)\) are identified as double poles at \(ai\) and \(-ai\). The residue at \(ai\) is calculated using the limit definition, resulting in zero, which is confirmed to be correct due to the nature of double poles. To compute the inverse Laplace transform, it is recommended to use the Laurent series expansion around the poles.
  • Understanding of inverse Laplace transforms
  • Familiarity with residue theory in complex analysis
  • Knowledge of Laurent series expansions
  • Proficiency in calculus, specifically differentiation and limits
  • Study the properties of double poles in complex analysis
  • Learn how to compute residues using Laurent series
  • Explore the application of the residue theorem in inverse Laplace transforms
  • Review examples of inverse Laplace transforms involving complex functions
Students and professionals in mathematics, particularly those studying complex analysis and differential equations, as well as anyone looking to deepen their understanding of inverse Laplace transforms and residue calculations.
PAR
The problem is to find the inverse laplace of \frac{s^2-a^2}{(s^2+a^2)^2}
I am supposed to use the residue definition of inverse laplace (given below)
The poles of F(s) are at ai and at -ai and they are both double poles.
f(t) = \sum_{j=1}^{N}Res[F(s)*e^{st};s_{j}]
Where s_{j} are the poles of F(s)
Residue(f(z)) = \frac{1}{(m-1)!}lim_{z->z0}\frac{d^{m-1}}{dz^{m-1}}((z-z0)^{m}f(z))
where z0 is a pole of order m of f(z)
If you can just help find the residue of ai I'm sure I can figure out -ai.
Residue[F(s);ai] = lim_{s->ai}\frac{d}{ds}\frac{(s-ai)^2(s^2-a^2)}{(s-ai)^2*(s+ai)^2}
= lim_{s->ai}\frac{d}{ds}\frac{s^2-a^2}{(s+ai)^2}
using quotient rule I get:
= lim_{s->ai}\frac{2s(s+ai)^2-2(s+ai)(s^2-a^2)}{(s+ai)^4}
substitute ai for s
=\frac{2ai(2ai)^2-2(2ai)(-2a^2)}{(2ai)^4}
=\frac{2ai(-4a^2)+8a^3i}{16a^4} = 0
But it can't equal zero right? I also get zero when I try to calculate the residue at -ai.
To compute residues the limit formula is (in general) not recommended. It is messy and you can easily make mistakes that you then can't correct easily by backtracking the calculations. Instead, you should compute the Laurent expansion around the poles using known series expansions.
E.g. to find the residue at s = i a, you put
s = i a + t
and compute the coefficient of 1/t:
[2iat + t^2 - 2a^2]/[t^2 + 2iat]^2 =
1/(2iat)^2 [2iat + t^2 - 2a^2] 1/[1+t/(2ia)]^2 =
1/(2iat)^2 [2iat + t^2 - 2a^2] [1-t/(ia) + O(t^2)]
So, we see that the residue is:
-i/(4a)
Yes, the residue of F(s) at s=ia is zero. Like you said, it has a double pole there; it will only have a non-zero residue if the pole is a simple pole.
To find the inverse Laplace transform, however, you need to calculate the residue of F(s)est, and that function does have a simple pole at s=ia. Like Count Iblis, I suggest you expand the function in a Laurent series about s=ia.
