Resistive force at constant velocity freewheeling down a slope
The discussion centers on calculating the average resistive force acting on a 960 kg car freewheeling down a 15-degree incline at a constant speed of 9.0 m/s. The key conclusion is that the average resistive force is 2.4 x 10^3 N, derived from balancing gravitational force and resistive forces. The gravitational force acting on the car is calculated as 9417.6 N, and since the car maintains constant velocity, the net force is zero, indicating that the resistive force equals the component of gravitational force acting parallel to the incline.
  • Understanding of Newton's second law (F=ma)
  • Knowledge of gravitational force calculations (F=mg)
  • Ability to resolve forces into components along an incline
  • Familiarity with trigonometric functions related to angles
  • Study the concept of force components on inclined planes
  • Learn how to apply trigonometry to resolve forces
  • Explore the relationship between constant velocity and net force
  • Review examples of resistive forces in physics problems
Students studying physics, particularly those focusing on mechanics and force analysis, as well as educators seeking to clarify concepts related to forces on inclined planes.
ocfx
Ok so the problem is this: A car of a mass 960kg is free-wheeling down an incline (15 degrees to the horizontal) at a constant speed of 9.0 m s^-1
- Deduce that the average resistive force acting on the car is 2.4*10^3N
F=ma I suppose, but it hasn't got me anywhere yet really any help would be appreciated.
I calculated that the force should be F=mg = 960kg*9.81 = 9417.6N. Now I don't see how this will help in deducing the resistive force, but since the velocity is constant the resistive force should balance out any other force acting on it.
Any help will be appreciated. Thanks.
draw a free body diagram with all the forces in it
split all forces into components perpendicular and parallel to the slope. (the usual thing to for
problems with slopes)
Could you or someone else clarify what forces would be involved despite friction and gravity. Also how will this help me deduce the resistant force acting on the car?
The forces are gravity and some unknown resistive force (which you are trying to find).
What's the net force on the car?
What is the acceleration of the car with the resistive forces?
What would be the acceleration of the car if there were no resistive forces?
The acceleration with resistive forces is 0 since the speed is constant but if there were no resistive forces the acceleration would be 9.81, right?!
That would be true if it were in free fall, but the car is constrained to go down an incline.
Right, so should I use trigonometry to prove it then that is sin 15 = 9417.6N/x ?
EDIT: that doesn't give me the right answer a little hint would be appreciated =D
That's incorrect.
What's the car's weight? What's the component of that weight parallel to the incline? (How do you find components parallel and perpendicular to an incline?)
Well could you explain the concept, because I'm not exactly sure of it?
Read all about it: http://www.physicsclassroom.com/Class/vectors/u3l3e.cfm"
  • · Replies 16 ·
  • · Replies 39 ·
