How Do You Calculate Resistance and Current in a Carbon Block Using Ohm's Law?
The problem involves calculating the resistance and current of a carbon block using Ohm's Law. The block is specified to have dimensions and a potential difference applied across it.
  • Conceptual clarification, Problem interpretation
  • Participants discuss the physical description of the carbon block, with one seeking clarification on its shape and dimensions. There is an attempt to visualize the block as a cuboid based on the provided measurements.
The discussion is currently focused on understanding the geometry of the carbon block. One participant has provided a clarification that seems to have aided another, indicating a productive exchange of ideas regarding the interpretation of the problem.
There is a request for a visual representation to aid understanding, suggesting that the description may not be entirely clear to all participants. No specific assumptions or constraints have been noted beyond the problem statement.
LeakyFrog
A block of carbon is 3cm long and has a square cross section whose sides are .5cm long. A potential difference of 8.4V maintained across its length.
a)What is the resistance of the block?
b)What is the current in this resistor?
R=pL/A
where p is resistivity
I'm fairly certain i can solve this problem right quick if I could understand what exactly the block looked like. The description just doesn't make sense to me. I'm not sure if you can draw pictures on this or not but a picture would be helpful if someone can make one. Thanks.
From what I've read the block is a cuboid. Imagine a square that's 0.5cm by 0.5cm, now stretch that back in the third dimension by 3cm, and Bob's your uncle. A similar shape to a packet of gum.
thanks dude (or dudette)! helped a bunch!
No worries mate.
  • · Replies 16 ·
  • · Replies 21 ·
