Resolving Algebra Problem: Finding Real Solutions for \sqrt{2x-3} + x = 3
  • Thread starter Thread starter sauri
The discussion centers on solving the algebra equation √(2x-3) + x = 3. Initially, the user attempted to manipulate the equation but arrived at incorrect solutions due to misapplication of algebraic rules. A recommended approach involved isolating the square root and squaring both sides, leading to a quadratic equation. After correcting their factoring method, the user found the correct factors to be (x-6)(x-2), identifying x=2 as the only valid solution. The importance of verifying solutions in the original equation was emphasized throughout the discussion.
sauri
I got this algebra problem that I have been trying to get around but the answer I get is always different from the book.
It says: Find all the real solutions, if any of each equation.
21). \sqrt{2x-3} +x=3.
I tried to resolve it using the following method:
2x-3+x^2=9
(2x-12)+(x^2-9)=0
2(x-6)+(x+3)(x-3)=0
(x+3) and (x-3) will cancel each other so;
2x-12=0
x=12/2
x=6.
However, this is wrong and I know it, cause the answer does not fit the equation. So can anyone help me point what's wrong with what I did?
Mathematics news on Phys.org
Yes, that's wrong! (a+ b)2 is not a2+ b2 so (\sqrt{2x-3}+x)^2 is not 2x-3+ x!
I recommend you subtract x from both sides of th equation to get
\sqrt{2x-3}= 3- x, with only the square root on one side and then square both sides.
If I use \sqrt{2x-3}= 3- x, I then worked it out to
2x-3=9-6x+x^2
2x+6x-x^2=9+3
8x-x^2-12=0
So I re-wrote as;
-x^2+8x-12=0
(x+6)=0 or (x+2)=0
but then the answers add up as x=-6 or x=-2. and that can't be right..
You didn't quite factor it correctly.
Try factoring -x^2+8x-12=0 again. You may want to move everything to the right hand side to make it a bit easier.
O.k, this time I tried the copleting the square method:
-x^2+8x-12=0
-x^2+8x=12
(x+4)^2=12+16
(x+4)=\sqrt28
4+\sqrt28 or 4-\sqrt28
The answers vary between -1.29 and 9.29, Still off
-x^2 does not factor as (x+...)(x+...). That's your mistake.
Rewrite -x2+ 8x- 12= 0 as x2- 8x+ 12= 0 by multiplying both sides by -1 (or "move everything to the right hand side" as was suggested before.
x2- 8x+ 12= (x- ?)(x- ?).
Of course, be sure to check solutions to the polynomial equation in the original equation!
ah, I got it. You end up with (x- 6)(x- 2).
and only x=2 would apply for the equation.
Thanks
