Resolving power of a compound microscope
7 replies · 2K views · last reply
rinalai
What is the maximum resolution of a microscope with water immersion microscope objective and red light illumination?
R=1.22λ/(NAobjective + NAcondensor)
R = 1.22*700nm/(1.3+0.95) ≈ 380nm
rinalai said:
Homework Statement:: What is the maximum resolution of a microscope with water immersion microscope objective and red light illumination?
Relevant Equations:: R=1.22λ/(NAobjective + NAcondensor)
I am not sure about the value of NAobj here. Is it <1.3 when using water-immersion objective?
Also, is NAcond always 0.95, or could it be of other values?
Thank you.
Remember that NA for any system in a material of index ##n## is ##n \sin\theta_{max}##. Looking at this formula, what is the largest possible value for the NA?
For water(n=1.33) the maximum should be 1.33, right?
How about NAcondensor?
Yes, that is correct.
How did you come up with 0.95 for NAcond?
I referred to the professor's slide(attached picture),
but don't understand how NAcond was determined..
So after doing a little research, it seems 0.95 is considered the maximum achievable NA for a dry lens. I couldn't tell you why it's 0.95 and not 0.96 or 0.94. However, the difference between ##NA_{cond} = 1## and ##NA_{cond} = 0.95## is only a 2% change in the value of the resolution. If you want to play it safe, just use the value of 0.95.
