- Messages
- 8,533
- Reaction score
- 18
Yes, in a LET there is such a thing as absolute simultaneity, and it corresponds to the definition of simultaneity in the aether frame, not in other frames.GrayGhost said:JesseM,
Lorentz's LET assumes apriori that an aether exists, that it does not move, and that all motion is relative to it as a master reference. Also, that light moves at c only wrt this aether frame. Einstein's SR requires that no frame is preferred even if an aether does exist, and light moves invariantly at c per each and all.
In this thread, it was mentioned that LET and SR are indistinguishable by measurement, because they possesses the very same transformations. Some readers will assume the one theory is as good as the other. Are the following true wrt the LET theory ...
If 2 clocks are synchronised by the Einstein/Poincare sync method, they are not in true synchronisation per Lorentz unless they are at rest with the aether. It doesn't matter what any other frame thinks.
In an absolute sense yes, although different frames can still have their own definitions of coordinate simultaneity which differ from absolute simultaneity.GrayGhost said:If 2 events occur, they are simultaneous only if deemed such per the aether frame's POV. It doesn't matter what any other frame thinks.
Yes, in the LT there is such a thing as absolute time.GrayGhost said:Tau is local time, which is not true time. True time is determined only by synchronised clocks at rest in the aether.
The principle of relativity deals only with the measurable laws of physics, not with absolute metaphysical truths. In LET (at least the version I was talking about) there is absolutely no experimental way to determine which frame is the aether frame, because the laws of physics obey the same equations in the coordinates of each frame (the equations are Lorentz-invariant, meaning if you know the equations in one frame and then transform into a different frame, you get back the same equations). This implies that if you have any experimental apparatus and you record the results in terms of the coordinates of the apparatus rest frame, the results will be the same regardless of which frame the apparatus happens to be at rest in (so if you are in a windowless rocket, there's no experiment you can do that will give a different result depending on whether the rocket is at rest relative to the aether frame or moving at some large constant velocity relative to the aether frame).GrayGhost said:One question ... how is the principle of relativity upheld under LET, given a master frame?
