Retrieving data from my old hard drive
  • Thread starter Thread starter tony873004
    Data Drive Hard
The discussion revolves around connecting a Quantum Bigfoot TX hard drive from a Windows 98 system to a Windows XP computer. The user successfully assigned the drive a letter (E) but encountered access issues, receiving an error stating that the drive is not accessible. The user attempted various jumper settings and configurations, including connecting the drive as a slave and removing the jumper entirely, but the problem persisted. The discussion also touches on compatibility concerns regarding FAT32 partitions and the absence of certain settings in Windows XP.
  • Understanding of hard drive jumper settings and configurations
  • Familiarity with Windows XP file system compatibility, specifically FAT32 and NTFS
  • Basic knowledge of connecting IDE drives to a motherboard
  • Experience with troubleshooting hardware recognition issues in Windows
  • Research jumper settings for Quantum Bigfoot TX hard drives
  • Learn about accessing FAT32 partitions from Windows XP
  • Investigate IDE cable configurations and master/slave settings
  • Explore advanced file sharing settings in Windows XP Professional
This discussion is beneficial for hardware enthusiasts, IT professionals, and anyone attempting to recover data from legacy hard drives, particularly those transitioning from older operating systems to newer ones.
tony873004
I am trying to hook up my old hard drive to my newer computer. I've done this before on a different computer with success, but this time it won't work.
My old hard drive is from a Windows 98 computer. It is a Quantum Bigfoot TX. My newer computer is Windows XP.
I unplugged my CD/R cables and inserted them into my old hard drive. It has a data cable with lots of pins, and a power cable with 4 wires.
My computer assigns it a drive letter of E. But when I open My Computer to E it tells me that drive E is not accessable.
If I'm interpreting it right, the online documentation ( http://perso.orange.fr/rayp/HD/QUANT...es/bf_a_tx.htm )for this hard drive shows only two settings for the jumper, either across the DS pins, or removed completely. I've tried both settings.
Here's some pictures to clarify what I'm doing:
The one that says master was hooked up to my CDRW/DVD-R drive. The one that says Slave was hooked up to the second (CD only) drive.
The pins. In this attempt, I removed the jumper completely.
The label from the hard drive. I don't understand what it is saying about the pins. And I'm not sure the link I provided above is the correct one for this hard drive.
During the bootup process, the green light on the old hard drive comes on a few times and it makes its hard drive woodpecker sound, so I know its getting power. It assigns it to drive E, but when I access it it does not make noise, nor does the green light come on. It says:
Computer science news on Phys.org
Quick MS Support search: http://support.microsoft.com/kb/810881/en-us
Don't know if that will work or not.
Honestly I don't even know if you can view FAT32 partitions from an XP install on NTFS. Maybe someone else knows.
Did you try and connect the old HD to the same cable as the new HD but using the slave slot? You will need to make sure you have the jumpers configured as a slave.
(BTW Your link doesn't work)
Yeh you can XP can read Fat32
Thanks for your help so far.
I just tried your suggestion and used the slave slot on the main HD cable. I removed the jumper completely from the old HD and I still get the same error.
Sorry for the dead link. Here it is:
http://perso.orange.fr/rayp/HD/QUANTUM/guides/bf_a_tx.htm
Dav's link might contain the answer. I'm going to try that now.
The computer seems to recognize the drive. When I right-click on drive E, it knows its a Quantum Bigfoot TX8.0AT. It says device Status: This device is working properly.
On Dav's link I get to the point where it says:
c. Under Advanced Settings, click to clear the Use simple file sharing (Recommended) check box, and then click OK.
But I don't have a Use simple file sharing check box. The closest I have is Display simple folder view in Explorer's Folders list.
Any thoughts?
It might be for XP Pro only.
http://home.comcast.net/~cubz2008/folderoptions.jpg
I guess it is XP pro only. I don't have that checkbox :(
9K
  • · Replies 52 ·
  • · Replies 22 ·
