Reversible processes and carnot cycle
The discussion revolves around the concepts of reversible processes and irreversibility in thermodynamics, particularly in the context of the Carnot cycle. Participants explore the relationship between heat transfer, entropy, and the conditions that define reversible processes.
  • One participant questions why heat transfer is considered irreversible and why heat addition in the Carnot cycle occurs at constant temperature to maintain reversibility.
  • Another participant explains that any process causing an increase in entropy is deemed irreversible, citing that the Carnot cycle assumes heat transfer occurs without a temperature gradient.
  • A participant seeks clarification on whether all processes that increase total entropy are irreversible, indicating a desire for a general rule.
  • There is a discussion about the relationship between entropy and irreversibility, with one participant noting that the heat addition process in the Carnot cycle increases system entropy yet is still considered reversible.
  • One participant suggests resources for understanding the relationship between entropy and irreversibility, recommending Zemansky's Heat and Thermodynamics and encouraging exploration of various textbooks.
  • Another participant emphasizes the importance of linking irreversibility to flow in response to a gradient rather than energy dissipation, providing a mathematical perspective on how this relates to entropy increase.
  • One participant expresses difficulty in understanding energy dissipation in processes other than friction, particularly in the context of heat transfer.
  • There is a reiteration of the idea that gradient-induced flow is a more useful framework for understanding irreversibility than the concept of energy dissipation.
Participants exhibit a mix of agreement and disagreement regarding the definitions and implications of irreversibility and entropy. While some concepts are clarified, no consensus is reached on the broader implications of these ideas.
Participants express uncertainty about the definitions and relationships between entropy, irreversibility, and energy dissipation, indicating that further exploration of these concepts may be necessary.
ahmedbadr
i want to ask why heat transfer is considered ti be an irreversibility and why in carnot carnot cycle heat addititon is at constant temperature to make this process reversible
Any smoothing of a gradient (in temperature, charge, matter, etc.) is thermodynamically irreversible because entropy increases; the universe can't be restored to exactly its former condition. In a Carnot cycle, heat transfer is assumed to occur without a gradient and from infinitely large thermal reservoirs. Although this arrangement is impossible in practice, it is useful to consider in theory because it enables a heat engine with maximum possible efficiency. Does this answer your question?
do u mean that any mprocess cuases an increase in entropy is an irreversible process?is it general rule?
thx for ur reply
Yes, any process that involves an increase in total entropy is irreversible.
ok can u tell me a website or textbook that explains this relation between entrop and irreversibilty?because in carnot syscle in the heat addition process there is increase in the entropy of system however it is cosidered to be reversible process .
thx
Zemansky's Heat and Thermodynamics is pretty good. If you're near a university library, browse for immediately readable thermodynamics books (actually flip through the selection and think about which ones you'd most enjoy reading) and compare their treatment. I learn best by scanning different books on a subject and seeing what they all mention and how it's expressed in different ways. Perhaps this approach works for you too.
Whenever flow occurs in response to a gradient, entropy is not just transferred but also created. Consider heat transfer between two bodies. If we assume one is very large (this is the reservoir), then the energy removed won't affect its temperature. If we also assume the temperature difference is very small, then entropy creation is minimal. Take these assumptions to their extreme and we have the Carnot cycle, where no entropy is created at all. There is still entropy transfer: the energy associated with heat transfer carries its own entropy. But the transfer is perfectly efficient, and what's lost by the hot reservoir is exactly gained by the engine. Later, when sending energy to the cold reservoir, what's lost by the system is exactly gained by the cold reservoir.
i laso ve another question i can understand the concept of irreversibility that there is energy dissipated in the process but i can uget that just for friction burt for other reasons of irreversibilities for example heat transfer i can't get whre is the energy dissipated here.thx
My advice is to link irreversibility in your mind not with "energy dissipation" but with "flow in response to a gradient that tends to erase that gradient." There are a couple advantages. First, gradient-induced flow is easy to quantify, by taking the dot product of the flow vector (in this case, heat flow and direction) with the mathematical gradient of the potential (in this case, the temperature). This dot product is actually proportional to the rate of entropy increase. Second, as you've pointed out, it's not easy to visualize "energy dissipation" when a hot object heats a cold object. It's an amorphous term (how is energy dissipated here?). But the gradient-induced flow view encompasses both friction (matter deforms in response to stress gradients, energy moves in response to temperature gradients) and simple heating/cooling. Swapping these descriptions in my mind was a key part of moving from beginner to advanced thermo.
nice description mapes:smile:
  • · Replies 33 ·
  • · Replies 57 ·
  • · Replies 19 ·
