Rewrite Indefinite Integral in Terms of Elliptic Coordinates
The discussion centers on rewriting the indefinite integral of the function (x+y) in terms of elliptic coordinates (u,v). The transformation involves substituting x and y with acosh(u)cos(v) and asinh(u)sin(v), respectively. Participants emphasize the need to compute the Jacobian determinant for the change of variables, which is crucial for the integral transformation. There is a focus on using the multivariable chain rule to derive the necessary expressions for dx and dy. The conversation concludes with a participant confirming their Jacobian calculation, indicating progress in the solution process.
wifi
Problem:
Rewrite the indefinite integral ## \iint\limits_R\, (x+y) dx \ dy ## in terms of elliptic coordinates ##(u,v)##, where ## x=acosh(u)cos(v) ## and ## y=asinh(u)sin(v) ##.
Attempt at a Solution:
So would it be something like,
## \iint\limits_R\, (x+y) dx \ dy = \iint\limits_R\, [acosh(u)cos(v)+asinh(u)sin(v)] dx \ dy ##. I need to calculate ##dx## and ##dy## in terms of ##u## and ##v##, then substitute them in the integral, correct?
The only thing that comes to mind is the multivariable chain rule: ## \frac{dx}{dt} = \frac{\partial x}{\partial u} \frac{du}{dt}+\frac{\partial y}{\partial v} \frac{dv}{dt} ## or ## \frac{dy}{dt} = \frac{\partial y}{\partial u} \frac{du}{dt}+\frac{\partial y}{\partial v} \frac{dv}{dt} ##
Any help is appreciated. Thanks in advance.
I should note that the task is to merely rewrite the integral, not to evaluate it.
Think Jacobian.
I'm sorry, can you be more specific?
I think I got it, hold on.
So I simply use ## \iint\limits_R\ f(x,y) dx \ dy = \iint\limits_{R^*}f(x(u,v),y(u,v)) det(J) du \ dv ##?
Yup.
Okay thanks! I'm going to LaTeX my work so you can see.
For the Jacobian I got ## J = (a^2sinh^2(u)cos^2(v)-a^2cosh(u)sinh(u)cos(v)sin(v))du \ dv ##. Is that correct?
I don't get that.
Darn. I'll try agian.
I think I messed up a negative. Now I'm getting ## J= (asinh(u)cos(v))^2+(acosh(u)sin(v))^2 ##
I'm not at my computer right now, but it looks like what I got.
Awesome! Thank you so much!
  • · Replies 28 ·
