How Does a Wifi Receiver Implement RF Systems Without Traditional Components?
  • Thread starter Thread starter Fischer777
    Receiver Rf Wifi
The discussion centers on the implementation of RF front-end systems in WiFi receivers, specifically addressing how these devices operate without traditional components like inductors and capacitors. Participants confirm that while WiFi chips are compact, they utilize external components mounted on circuit boards, such as capacitors, to achieve necessary filtering and signal processing. The conversation highlights that modern Large Scale Integration (LSI) chips can incorporate reactive elements, allowing for the construction of filters directly on the chip. The MAX2830 RF WiFi chip is referenced as an example of a device requiring a companion digital MAC/PHY chip for complete functionality.
  • Understanding of RF front-end systems
  • Familiarity with Large Scale Integration (LSI) technology
  • Knowledge of WiFi chip architecture
  • Basic principles of signal filtering and processing
  • Research the design and functionality of the MAX2830 RF WiFi chip
  • Explore methods for integrating reactive components in LSI chips
  • Learn about variable filters and their implementation in RF systems
  • Investigate the role of external components in WiFi receiver performance
Electronics engineers, RF system designers, and anyone interested in the architecture and functionality of WiFi receivers and integrated RF systems.
Fischer777
I am curious to know how the RF front end of a Wifi receiver works. From my understanding, most RF receivers have to use networks of various oscillators, mixers, and filters to select a given frequency and remain insensitive to undesired signals at different frequencies, and I suspect that WiFi is no different (although I could be wrong). However, Wifi chips are small and to my knowledge don't contain any elements usually used to implement oscillators and filters (like inductors and capacitors). So my question is, how are Wifi devices able to implement those systems? I guess this question doesn't apply specifically to Wifi, but any device that uses a integrated receiver system.
good response, mebigguy
and I just had to post that block diag here for ease of viewing ...
To the OP, so you can see that all the physically larger components caps and inductors are mounted on the circuit board outside of the chip
I can see at least 2 caps on the inside ( probably REALLY small values)
This is typical of a lot of LSI ( Large Scale Integration) chips for all sorts of transmitters and or receivers 2-waqy radios, TV/ FM Broadcast receivers
WiFi, Cellphones etc etc
Dave
One reason I like arduino - all of the common shields are open source -- here is the complete schematic of the WiFi shield, so it shows the external components Davenn mentioned.
You can buy (if you are an OEM) 2.4GHz wireless audio systems with the complete system (RF/PHY/MAC/ADC/DAC/AMP/Battery charger/USB, etc etc) on a single 3.3V chip. External capacitors and flash are about it for external components.
Thanks for the info guys. I guess my question pertains specifically to what appear to be the variable filters on the diagrams. All filters I'm familiar with need some reactive component, like an inductor or capacitor. Is some technique used to build the reactive elements in the the chip itself, or does it use the external capacitors for this purpose. Or, is there a method of implementing such filters without the use of reactive components?
That is just a block diagram that is shown above. It just shows the significant components, there are likely to be many more if you could see the full schematic diagram
You can build inductors and capacitors on chip.
  • · Replies 17 ·
12K
