Undergrad Riemann Tensor: Questions & Geometric Interpretation
The discussion centers on the Riemann tensor's role in describing the variation of a vector when displaced parallel in a closed loop formed by geodesics. Different authors present varying formulas for this variation, with some incorporating a factor of (1/2) derived from Stokes' Theorem, while others do not. The discrepancies in these formulas raise questions about the underlying justifications and the significance of the signs used in the expressions. The contributor seeks clarification on these differences and their implications for understanding the geometric interpretation of the Riemann tensor. The conversation emphasizes the need for a deeper exploration of these mathematical nuances.
victorneto
Tensor of Riemann. Geometric interpretation.The Riemann tensor gives the variation of a vector displaced parallel in a closed loop, say a small rectangle formed by geodesic sides, (δa) and δb) first, starting from a vertex A and going to another vertex in the diagonal, B; then starting from the same vertex A and going to B, using the other route. In B, the vector Vi will change to V'i, such that the variation will be given by:
ΔVi = + (δa) (δb) RijklVjUkUl,
where (δa) (δb) is the area of the infinitesimal rectangle, and Uk and Ul are unit vectors tangent to the trajectories. The question I put to discussion and clarification is as follows. 1) Most authors, B.Shultz, Dunsby, Professor H. Fleming (USP, São Paulo, Brazil), among others, make the deduction of the above formula, using the scheme described above and detailing, used in the use of indexes.
2) Other authors, such as Baez, give the above formula as
ΔVi = - (ε) 2 RijklVjUkUl, + (Oε3)
(Certainly incorporates in (Oε3) the approximations for the 1st order that does, in several phases of the calculations).
But Landau, in Theory of the Field, formula (91.5), p. 342, finds the following expression:
ΔVi = - (1/2) RijklVjUkUl, Δfkl,
where Δfkl is the infinitesimal area bounded by the two paths; that is, represents the product (δa) (δb) UkUl
(In some formulas the sign (-) appears in other o (+), without further explanation.)
The formula ΔVi = - (1/2) RijklVjUkUl, Vj Δfkl,
obtained by Landau incorporates the factor (1/2), was obtained using the powerful Stokes! Theorem, which gives definite and definitive results, while the previously commented formulas were obtained in a geometric tour de force, step by step, and where it does not appear in the final result, said factor (1/2).
I checked all the calculations (that is, I have refined all, to convince myself, and, from the point of view of mathematical procedure, I found nothing to justify the absence of the factor (1/2) obtained through Stokes; it is necessary, as I said above, to make numerous approximations throughout the deductions ...).
But, objectively, I have doubts. I have not found out yet what lies behind these results, or what justifies them, against Landau. And I also understand that the signal that precedes the expressions should not be mere conventions, but the result of the difference between vectors against and covariates. If covariant, (+), if contravariant, (-).
Could you clarify?
.I request the special finesse of moving the post Tensor of Riemann - Geometric interpretation to the forum Differential Geometriy.
Muito grato.
MOVING CLOCKS In this section, we show that clocks moving at high speeds run slowly. We construct a clock, called a light clock, using a stick of proper lenght ##L_0##, and two mirrors. The two mirrors face each other, and a pulse of light bounces back and forth betweem them. Each time the light pulse strikes one of the mirrors, say the lower mirror, the clock is said to tick. Between successive ticks the light pulse travels a distance ##2L_0## in the proper reference of frame of the clock...
  • · Replies 26 ·
  • · Replies 28 ·
