Is There a Mistake in Solving this Right Angle Triangle Problem?
  • Thread starter Thread starter chemistry1
    Angle Triangle
The discussion focuses on solving a right-angled triangle problem where the acute angles are expressed in both degrees and grades. The initial calculations led to incorrect values due to a misunderstanding of the conversion between degrees and grades, specifically using a denominator of 9 instead of the correct 10. The correct relationship shows that 1 degree equals 10/9 grades, leading to a proper equation for the angles. Participants clarified the meaning of "grades," noting that it refers to a system where a right angle is divided into 100 parts, known as grads. Ultimately, the error was identified as a simple miscalculation in the conversion process.
chemistry1
The number of degrees in one acute angle of a right-angled triangle is equal to the number of grades in the other; express both the angles in degrees.
So I have found the following answers :
810/17=47,05... degrees and 810/17=47,05... grades which gives 42,35... degrees
Now, the real answer is the following :
900/19=47,3... degrees and 900/19=47,3... grades which gives 42,63... degrees
The only problem with my answer is the following :
810/17degrees=900/17grades
so : 900/17 grades+ 810/17 grades = 100,5.. grades (but for the rest, everything is fine, I get get 90 degrees perfectly and respect all conditions.)
Would you count this as an error ?
Here's what I did : (Help me see the error)
x degrees= (x+x/9) grades
x grades= (x-x/9) degrees
so..
x degrees+(x-x/9)degrees=90 degrees
17x/9 degrees=90 degrees
17x=810
x=810/17 degrees
By the formulaiton of the problem, we also have 810/17 grades
Conversion
810/17 degrees=(810/17+(810/17)/9) grades=900/17 grades
and
810/17 grades=(810/17-(810/17)/9) degrees= 720/17 degrees
Can somebody tell me where I went wrong ? (By the way, I see how to obtain the "real" answer, but I don't see why mine would be wrong ...)
Thank you !
Can you explain what the term "grades" means? I've never heard of that term and a Google search isn't showing any useful links.
Thanks for the link! Took me a little bit, but if ##1^{\circ} = \frac{10}{9}^g##, then ##1^g = \frac{9}{10}^{\circ}##.
##1^{\circ} = (1 + \frac{1}{9})^g \implies x^{\circ} = (x + \frac{x}{9})^g##
##1^g = (1-\frac{1}{10})^{\circ} \implies x^g = (x-\frac{x}{10})^{\circ}##
Basically, the fraction is supposed to have a denominator of 10, not 9.
So you solve the equation ##x + x - \frac{x}{10} = 90##
Oh,wow, I just noticed my error!(With the 10) Thank you ! Thats why I was getting a wrong answer !
Yes, it's working ! Those are the times when I feel really ashamed of myself for doing stupid errors like this one -_____- Thank you agian!
We've all been there, I assure you! :biggrin:
I am used to that being called "grads", not "grades". (And "gradian" is too easily confused with "radian".) There are 100 grads in a right angle so that it measures "percentage slope".
  • · Replies 34 ·
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 22 ·
